Hello all,
We're selling this customized CVT Trailer at NO RESERVE on BringATrailer: No Reserve: 2017 CVT Off-Road Travel Trailer It was used by The FJ Company for demonstration in events such as Cruise Moab, FJ Summit, and Overland Expo. The trailer was used for actual camping no more than 5 times. When not in use, it was stored inside a climate controlled facility. The trailer is currently located in Miami, Fl.
The base trailer and the CVT Denali tent were purchased new from CVT in 2017 and subsequently sent to Rocky Mountain Four Wheel Pop-Up Campers in Denver, Colorado for additional modifications. Exterior features include Rotopax 4-gallon water and fuel tanks, Maxtrax traction boards, a Krazy Beaver shovel, fire extinguisher, and a Max Coupler hitch for towing. For camping and overland use, the trailer features an Engle MT60F Fridge-Freezer mounted on a Tembo Tusk Extreme Duty drawer, and made accessible through the rear access door of the trailer. The fridge and other electrical features are powered by a 12v deep cycle battery. The battery can be charged via twin Zamp solar panels, or by the tow vehicle through a 7-pin trailer connector. When “on shore” the battery can remain charged via a 120v plug through a Noco Genius 10 battery charger. The trailer also features a 20 gallon fresh water tank which can be used for showering through an externally mounted hand-held shower head. Finally, the trailer features an externally mounted propane tank which can be used with a Magma Stainless Steel Grill. The complete list of features is detailed below.
Please note that the trailer hatch must be opened by two people given the weight of the Denali tent. Once opened a few inches, the gas shock struts provide support for the hatch. We recommend using the Hood Prop (included) to keep the hatch open when working on the trailer.
- 2017 CVT Trailer (Manufactured by Buckstop Truckwear)
- Rear access door with lock
- Hatch for full access from above (Gas shock struts for support)
- 3500 lb HD Timbren axle-less suspension
- Denali CVT Tent (5 person tent)
- 33” BFG M/T Tires
- 2” Max Coupler Trailer Hitch
- Wired for battery charging (from tow vehicle through 7-point connector)
- 4 Gallon Rotopax for Water
- 4 Gallon Rotopax for Fuel
- 4x Maxtrax traction boards
- 10lb side mounted propane tank
- Water spigot (from internal water tank)
- Shower head with handle/hose (from internal water tank)
- Side mounted aluminum work/kitchen table
- Fire extinguisher
- Krazy Beaver Shovel
- Engle MT60F Fridge-Freezer (shore power cable included)
- Tembo Tusk Extreme Duty Drawer
- Deep cycle 12v Battery
- Noco Genius 10 - Shore power Battery charger
- 20 gallon Frontrunner fresh water tank (for shower or exterior spigot)
- Shower system with electric pump
- Frontrunner fold out cutting board
- 12v / USB Plugs
- 2x Zamp Solar Panels
- Magma Stainless steel grill
- Kariba portable water heater shower system
