Endurance
WY Adventurist
Hello all! This is my build thread for my 2006 Hummer H3 base model. So to start off I tell you a little about how I got into the Overlanding community. It originally started with my little brother recommending a youtube series to watch and it happened to be the Expedition Overland guys and their Alaska/Yukon trip. My Brother and I were instantly hooked and have been prepping for our first Overlanding trip. We'll save that for a different thread.
Now on to the build. I bought the rig in early 2014 as my first car, I had been looking around at 4runners and Tacos but I ultimatly decided on the Hummer because 1) I had experience with the vehicle because my dad had a 06 H3 Adventure when I was younger and 2) It was unique and you don't see a lot of them out there on the trails.
This was the truck as I got it from the dealer, with really small tires. For me the first order of business was to get larger tires and level the truck. Now unannounced to me my parents took my truck under the guise of a recall and got me new tires and a level for graduation my senior year which made the truck look much better and something I was very grateful for them doing.
The tires are 35" ProComp Xtream A/T s, overall they are a fair tire with good traction and off-road performance. That summer my family and I took a trip up to Leadville Colorado for a week of wheeling and fly fishing.
The Raptor is my Dads current rig and it is a beast of an off-road vehicle!
Poser rock pic
To say the least, that trip taught me quite a bit about how to pick your lines, tire placement and how valuable a spotter can be on rocky sections of the trail.
After the trip, I knew that I needed better shocks to help handle the rougher trails and add safety to on-road driving as well, so I went and bought a set of Bilstein 5100 shocks for all four corners of the truck.
And I added some rear tail light guards
As I continued to add to the list of things I wanted to do to the rig, the first and for most was adding a little bit of power to the 3.5L inline five cylinder. So I added a cold air intake and a performance filter.
The filter was from Green Filter USA and the intake was from Air Doc, who specializes in Hummer products.
While I was under the hood I also added an ARB Diff Breather kit that I had gotten and hadn't had the chance to install along with a Cobra CB radio.
So far that's what I've added to the rig. Up next on the chopping block is putting on an ARB Bull Bar with a Super Winch 9500lb Synthetic line terminating with a factor 55 Flat link, adding a rear ARB locker and compressor and stronger tie rods. This rig still has a bunch of mods to go and many more trail miles yet to be seen.
WY Adventurist
Forgot to add while I was doing the original post was that I had also built a drawer system and installed a ram mount for my tablet/nav system.
Overall the build went well until I started on the carpeting, which was a major pain in the but to put on. It wasn't as flexible as I had first hoped it would be but I made it work.
I have to say that the Ram mount was much easier to put in than this was, but hey it's a good learning experience.
I then replace the shifter boot because the pleather on that had begun to just disintegrate into black dust. Also added red accent stitching to it, I thought it looked pretty cool.
Reactions: Rusty burbin
Pap SJ
You wouldn't originally think of a Hummer as the way to go for overlanding especially considering the amount of solely road-driven ones; glad that you picked it! You have good taste for types of interior mods as well. Good to see other large GM drivers in here
WY Adventurist
Overall the 5100s are a good shock and have a nice ride quality. I would rather have a complete set of ICON reservoirs for the truck but as they don't make them for the Hummer, these are definitely worth the buy for better shocks.
Reactions: snewcombe and TMP
TMP
Colorado
Todd
Powers
KE0ONM
Sweet build! Def don't see many of these.
WY Adventurist
Alrighty so here comes some more mods to the Endurance! I was finally able to get my hands on an ARB bull bar for the truck along with a Superwinch Tiger Shark 9500 SR and KC Pro 6 led rounds in a spread pattern.
So the first thing that I needed to do was set up the solenoid with a remote location kit which was pretty simple and straight forward.
I then had to rotate the gear box so it would fit correctly within the bumper allowing me to access the clutch.
I then went on to feeding the line through the drum and that's where I ran into trouble and wound up having to drill press the hole in the drum slightly wider to accommodate the winch line. It was just a few hundredths of an inch but was enough for the line to feed through smoothly.
Then it was on to unwrapping this bad puppy!
I started by mounting up the winch and getting it prepped for install onto the vehicle.
I had to do a small amount of fabrication to the solenoid for it to mount to the bumper correctly because its curved on the bottom so it sits flush on the winch motor when it comes in the box.
I just used a small thing of aluminum that you can find a lowes and I cut it to measurement with a Dremel and mounted it up.
Once I had everything wired up on the winch I started disassembling the front end of the truck.
I finally finished late that night after quite a few distractions.
The next morning I realized that my driver side blinker was backward and fixed it.
The next day with everything done and wired, although I'm still waiting on the front skid plate adapter for it so, unfortunately, I can't take it on a test run just yet.
What really surprised me was the simplicity of the install, even with sorta kinda halfway decent directions.
Rusty burbin
Hesperia, CA 92345, USA
Jonah
Gregg
Love it!
Rustyburbin from SoCal 5 kids, wife, dog and a 1970 K20 Suburban
TMP
Colorado
Todd
Powers
KE0ONM
Lookin' good!
I installed that same winch not too long ago.
WY Adventurist
Got some new goodies in a few days ago. I just have to get them installed and wired up!
I decided to get the backlit version so it would be a little bit easier to see at night.
Reactions: Wawa Skittletits
WY Adventurist
So, after waiting a few weeks I finally had the chance to get my S-Pod installed. I didn't do this one myself because I wanted it in the headliner, so I took it to Lone Star 4x4 which is a veteran owned and operated shop here in NTX. I have to say that they did a phenomenal job getting everything done up and installed well. Oh and as a side note as well, I got a Factor 55 Flat Link in yellow.
Graeman
Todd
Hoffmaster
KJ7CRJ
Air Force
Great build you have going on here. It is nice to see something different than the common vehicles. I really do like those H3's, especially the pickup version.
WY Adventurist
Alrighty, so I haven't posted in a while and I decided that I should update the build thread. I went and bought a few things that I'll be using for my cooking set up. Some utensils, a cutting board, and a Coleman Dual fuel stove. I chose the dual fuel over propane because it allows me to use not only the regular stove fuel but also unleaded gasoline in emergencie situations as well.
I also bought a portable ARB air compressor with accessories and a Rode microphone that I can use on my DSLR for filming. I decided to move away from getting an air locker for the main reason of I have no space in the engine compartment to fit one, especially since I want to have front and rear lockers and that requires the dual air compressor from ARB. So in lue of that, I'll be going with the Eaton E-lockers instead.
Reactions: Badmeat
