Cutting down road noise....
BlueLineOverland
Local Expert, Arkansas USA
Experimenter II
6,585
Ozark Arkansas
Mason
Berry
Can anyone give suggestions on cutting down road noise? I thought about DynaMat but its so expensive I wasn't sure if that was the only way to go. Thank you for any help!
Reactions: SgtMac
Germantown, WI, USA
Christopher
Owens
Reactions: BlueLineOverland
JungleSkunk
Colorado, USA
Christopher
xxx
Army
Ive read about fender well and other undercoatings being used to dampen sound. Even bed liner type products have been used but I have limited experience with it other than slapping it on my bumpers for its normal intended uses.
This stuff also looks promising.
Hartford, SD
I've tried the bedliner but without putting the carpet back in it didn't make a big difference. Maybe the commercial ones that are really thick would be more effective. This time I'm using lizard skin and some 3/8 thick automotive sound insulation. And putting the carpet back in! Should be much quieter.
BlueLineOverland
Experimenter II
6,585
Ozark Arkansas
Mason
Berry
Please let me know how it works out
SgtMac
Tucson, AZ 85747, USA
Jon
McGuire
USAF Ret.
I have used Noico 80mil with pretty good success. Goes on easy, sticks really well. I did 4 doors and back cab wall of my Tacoma, with noticeable improvement. Plan on doing the entire floor as well, when I get the time.
Flipper
Florida
F
Sonic Barrier. Parts- Express.com Same as Dynamat 1/2 the price. Did the wifes Outback cut noise down around 30%. Good instructional video. Used the UT on the floors where thickness was an issue and the MX on the walls that is about a 1/2” thicker with a extra layer of butyl foam. Super sticky, I laid the sheets in the sun before installing, it was much easier to work with.
Hartford, SD
I don't have it back on the road yet. But after banging on the sides after the lizard skin the tinny and echo are almost completely gone. I also sprayed some between the 2 layers of the roof when I had it open.
Boostpowered
Hunt county, TX, USA
Davis
Freshen up your suspension and dont run mud tires. If its the body rattling you can use sound deadener mats but that stuff can get pricey real quick, could alo put truck bed liner on inside the cab also gets pricey.
58-fc170
Just add 6 gallons of lizard skin and that should keep it quiet. (i did it on my project in my build thread and it made a huge difference) :sunglasses:
Be careful with truck bed liners inside a cab as they off gas and those fumes aren't good for anyone.
