Coleman Oven - Stone or Griddle Heat Spreading Recommendations
Tundracamper
Tuscaloosa, Alabama, USA
Shepard
I have an oven on order and am interested in hearing what folks use to even out the heat in this oven. I see recommendations for putting a tile in the bottom. I’d rather have something that’s dual purpose, like a griddle that I can also cook on stove or a pizza stone. I am concerned I can’t find a griddle that will fit without a handle or that a pizza stone will break in transit.
What do you use and what all will it help cook besides using in the bottom of an oven?
lhoffm4
Boise, Idaho
Lee
Hoffman
US Navy
Pizza stone or ceramic tile- heats evenly over surface of tile, helps regulate oven output temp,
grubworm
louisiana
grub
worm
USN-Submarines
we use a pizza stone made from Cordierite which is a synthetic stone material that is quite durable and can take a decent shock without breaking
huachuca
tarboro nc
Al
Killebrew
I found a piece of shale about an inch thick and roughly the same dimensions as the oven while camping outside Bryce Canyon NP several years back and its worked well.
Tundracamper
Shepard
That solves it - road trip to Bryce! May have to check if there is anything better at Zion or Canyonlands.
I did order a 9” pizza stone. It was under $20. That seems like it’s multi-use. I can put it in bottom of oven if baking something in a regular pan on shelf, or use pizza stone on shelf for something like rolls. Isn’t that the way you use it, putting stone on shelf when food is on the stone and in the bottom when using it to even out heat?
huachuca
tarboro nc
Al
Killebrew
Nah, we poked around southern UT for over a month and Bryce rock is top shelf stuff compared to what you might find in the other areas. Mine even has a little Trilobite on one side. Better to find it outside the Park though - you know how picky them pesky rangers can get sometimes. The second shelf works best for biscuits, rolls etc. Cakes, brownies and such turn out best on the lowest shelf. Anything on the top shelf just turns black ....... quickly.
Reactions: Tundracamper
terryg
Nixa, MO, USA
Terry
Gandy
I use mine on a low(er) BTU butane stove. I didn't have any issue with burning with pizza and biscuits.
