Listing my Bush Company AX27 (previously sold by CVT Tents as the AX27 formerly Alpha tent); all aluminum frame, double layer ripstop canvas and with included rear rain fly (detachable for high winds). Tent is pre-wired with Anderson plugs leading inside the tent where you will find 2 receptacles on each side totaling 4 USB, 2 12v, and 2 additional Anderson plugs for power supply. Tent also has a preinstalled light with; white, amber, and red options. Aluminum frame is a 3 channel configuration with two additional channels on the top (ie you can mount just about anything to the tent itself).
Features:
Tent is pick up only, and you will need to bring a trailer/truck to carry it out (fits perfectly and securely in a U-Haul trailer).
Interior is in great condition, exterior frame has light pinstripping on the powder coat, and a small dent on the R/F corner that was there when we purchased it. No exposed aluminum, this coating is incredibly sturdy.
DM me for any further questions.
Features:
- External Length: External Frame 2.25m /7′ 4.6″ (2.32m / 7′ 7″ inc hinges & handles)
- External Width: External 1.4m (4′ 7.1″), 1.45m (4′ 9″) including gas struts
- Height (exterior, closed): 278mm (10.94″) including roof rails and base extrusions
- Max Height (exterior, open): 1.75m (5′ 9″)
- Max Height (interior, headroom open): 1.7m (5′ 7″)
- Internal Mattress: Length 2.13m / 7′, Width 1.28m / 4′ 2″, Thickness 80mm / 3.15″
- Weight: Approximately 99Kg (218lbs) excluding telescopic ladder
- 2.6m Telescopic ladder, second ladder mount and universal fitting kit/brackets supplied as standard
