If you're building out a Bronco with the Capable bumper for overland trips, this 40" PRO bar adds serious light for camp roads and trails and follows the bumper's curve so it looks factory.
Fitment
Install
Light output
The PRO light bar uses a Combo Pattern, blending spot and driving optics for a balance between distance and width.
Every PRO bar is dual function, one off-road main beam that runs alongside an amber DRL (daytime running light) backglow.
White: Super bright, crisp white beam with plenty of light for any adventure.
Yellow: Cuts through dust, fog, snow, and rain far better than white light. Ideal for poor conditions.
Amber DRL, Both colors come with the same amber daytime running light backglow. Doesn't give off much light, just a bold amber glow that makes your vehicle stand out on the road.
Build quality
Here's the 40" PRO output:
Questions about fitment on your rig? Ask here and we'll help.
2021+ Ford Bronco Capable Bumper 40in Light Bar PRO
Fitment
- Fits 2021–2026 Ford Bronco
Install
- Perfectly follows the Ford Bronco Capable bumper curvature
- Stays slim to the bumper for a sleek, built-in look
- Quick and simple install
- No cutting or drilling required. The kit is a complete bolt on using factory openings and hardware
Light output
Build quality
- Higher light efficiency: brighter, longer irradiation distance
- Housing is upgraded to 304 aluminum. The surface is UV polyester powder coated to protect against UV, salt water, corrosion, fading and scratch resistant
- Equipped with thermal management system that automatically adjusts the brightness output according to the external temperatures
- Rated for a 50,000 hour lifespan
