- First Name
- Matt
- Last Name
- Lewandowski
- Member #
25489
- Ham/GMRS Callsign
- KG4DIE
You are on a good path with asking about a used radio... may not have all the latest bells and whistles, but still more likely to give you more bang for your buck. Kenwood is not the only supplier of good radios. (especially if you are buying used) also consider Alinco, Icom, and Yeasu. all four brands produce EXCELLENT radios in every category (base stations, mobile and handhelds... Well o.k. I am not sure if Alinco makes base stations, but I do know they have great mobile radios which can be used in a vehicle or as a base station.)
The key thing I would look for in a used radio is that it is a dual band (2m and .7m is THE standard) and has a dual channel receive (meaning you can listen to 2 channels on 2m, or 2 channels on .7m, or one channel on each. this allows you to run on your favorite repeater, but also monitor simplex. MOST dual band radios support this feature. (yes you can probably get a 2m single band radio for even less used, but if you can find a used dual band mobile in your budget, I think it will give you the most bang for your buck.)
If getting a mono bander, start with 2m that will be the most useful band for you starting off.
If you end up getting a new radio, I just did a quick search of Ham Radio Outlet Alinco and Yeasu each have 2: 2m single band radios in your budget, Icom and Kenwood each have 1: 2m station, in your budget. Dual band will push it further up into the $300+ range for a new radio
Another option to look at is just getting an HT to begin with (again looking at both the new AND used markets to find what you want.) but keep in mind an HT will mean working with 5 watts instead of 50 so your effective range would be very reduced. I spent the first 5 or so years of my amateur radio career with just an HT but I got a decent low budget magmount antenna to help extend it's range. I could often hear people that I could not talk to because of the difference in power from their mobile rig to my hand held, but you could then later upgrade to a mobile, or there are a few companies out there that have amplifiers designed to boost a HT to mobile strength (typically mobile radios have 50w on 2m and 35w on .7m) Using that HT with an external antenna was plenty good enough for hitting the repeaters in the Tennessee Valley area. HOWEVER from a perspective of being a means of communications when Overlanding. The HT on it's own will not have the range to hit distant repeaters reliably enough to be considered emergency communications, but it will be plenty to keep you in touch with other vehicles in your group as long as they are within a hand full of miles of you.
And now for a word on Baofangs: Baofangs are low budget radios... a LOT of Hams out there use the UV5 HT and they also have mobile radios out there (though I have not heard anyone really mention the mobile radios in a couple years). They are something of a polarizing topic in the ham radio community. Some people love them because they are cheap and functional, others HATE them because they are felt to be low quality (including complaints that the signal splatters well outside of the target frequency)... Honestly I wish the UV5 had been available when I was starting out. I think it would make a decent beginners Handheld, but I would not buy one for myself now (I honestly can not speak for the Baofang mobile radios as I saw reviews (both good and bad) when I was not looking for a radio so I did not pay much attention to them). I have seen more than a few articles that UV5s can be programmed to operate on GMRS and FRS frequencies, but the FCC is not pleased with this. It is ILLEGAL to operate them outside the amateur bands even if you have a GMRS license. <Edit>: I stated last year that I would not buy a baofang for myself at this point... As I reread this post, I feel that that was not an entirely true statement. It was poorly written. More accurately it should have read that I would not buy one as my primary HT at this point. I can afford and would prefer more bells and whistles at this time. I would however consider getting one as a back up radio, or as a radio I could loan to newly licensed hams.
