Looking for some advice on lens color for lighting. I will be using a bumper that integrates a 30" Baja Designs light bar and has 2 Baja Design lower flush mounts on the sides. I was also planning to add some ditch lights on the A pillars. I don't have a lot of experience with amber lenses but heard they help in dusty/foggy conditions.
I was thinking about doing the light bar in a Driving/Spot combo in white. I'm leaning toward amber for the 2 lower mount fogs with a wide cornering lens. I'm not sure what to do with the A-pillar ditch lights. Some people recommend a spot pattern so you eliminate the hood reflections. Others recommend a wide amber and angle them outward. I see that Rigid makes a light that has LED facing forward and to the side for this application.
They will all be switched independently using a Switch Pros 9100.
Any advice from those with experience in this area?
Thanks
Thanks
