Allegheny-Shenandoah Overland Loop?
Roofus
Swamp
Bronco
Roofus
Friends - I'm looking for info on the Allegheny-Shenandoah Overland Loop. Mainly trying to figure out if there is a set route and what trails are included, or it differs by adventurer. My understanding is that one route includes: George Washington National Forest, Flagpole Knob, Reddish Knob, Lake Moomaw, Monongahela National Forest, Canaan Loop, Dolly Sods, and Green Ridge State Forest. I can build my own route with onX through these areas, but wanted to first see if anyone knew if there was a set route for this loop. Also, if anyone has made this trip, I'd be very interested in anything we need to watch out for and any advice on the water crossings. This would be a fall run, so I've heard your more at risk of wet carpets in the spring than at other times of the year. Thanks for any advice that can be thrown my way! Cheers!
Mr_Mnml_Engnr
California, St. Mary's County, Maryland, United States
Anthony
Trombley
Are you referencing the "Allegheny Discovery Route" found on the Overland Bound One app? I too am interested in doing that trail sometime, but I believe the app provides a .gpx file for you to use to navigate. If you do decide to run that route, I'd love to hear your review of it! I believe you can add a review of the trail on the app. The only review up right now it from the original trail creator in 2021.
Reactions: Roofus
Krusty
Richmond, Virginia, USA
brian
columbo
I've made some of those water crossings, they're like big puddles that can be anywhere from 6" to maybe 30" deep and up to maybe 30' long, depending on time of year and of course rainfall. It's been really hot and dry so I doubt those will be much of an issue for you. Going up the Union Springs trail (to Flagpole knob) this weekend but not expecting much difficulty. The "trail system" is mostly fire roads, rocky and bouncey at times but not difficult in general. I'm pretty sure someone will read this and have other stuff to share
Enjoy the trip!!
Reactions: Roofus
Roofus
Swamp
Bronco
Roofus
Thanks for the feedback everyone. I'm sorry for the slow response as I've just been swamped with work.
Krusty, Appreciate the feedback on the water crossings. I'm in a Bronco on 35's with 3" lift, so it sounds plenty manageable without worry about wet carpets.
Mr_Mnml_Engnr, I am not sure. I will have to look that up.
Kevin, yes I have that download from Gaia. I use onX Offroad and did the import. It seemed a bit off in places, so I went back through and basically recreated the route in onX by creating a new route that traced the loaded Gaia file. I'm only about 25% of the way back through the route tagging gas stations and camp sites from the Gaia map. And I'd like to add a few more tags of good lookouts/site seeing as I research. And I may have to adjust camping sites based on terrain. I tent camp so I can still take the roof off the Bronco, so rooftop tent sites won't work if the terrain is bad.
If I can get all of that done this month, then we are going to shoot for a late Oct or mid-Nov trip. I also need to get a sat communicator since there's no cell coverage in the south areas of the route as well as getting my air compressor installed (wiring is done, but need to install mount and compressor) before we made this trip. We will most likely have myself and a Prado making this trip. But based on "most" of the camping areas I've seen, I think we could do a 5 truck caravan pretty easily if not more. So I'd be open to meeting up with anyone who'd want to tag along.
I'll check in with more as soon as I'm able. Cheers!
Krusty
brian
columbo
<But based on "most" of the camping areas I've seen, I think we could do a 5 truck caravan pretty easily if not more.> Most of what I have seen can do 4 or 5 trucks as long as you're rooftop camping. There are some good sized sites but not huge. Good news is that many of them are very close together, a short stumble of less than a minute for most of them :)
John Bishop
Harpers Ferry, WV, USA
Bishop
Enjoy the trip!!
How was Union Springs? I went in that way last Nov and there were a couple of ledges that had gotten dug/ rutted out that gave a bit of a pause with a stock suspension JKU. It wasn't that bad the previous times I traveled that route.
Reactions: Kevin108
Krusty
brian
columbo
Didn't make it up there between the rain a few days early and what was predicted on Saturday and a family thing that came up out of nowhere. So sadly I can't give a trail report, I'm trying to get myself together and take another run at it this weekend or next
CLARO86
Central PA
LaRoche
USN vet
I am planning to do most of if not all of this route near the end of October with some friends. I'm still adding things to my plan, but cant wait to get out there for a week.
bear_den_overland
Pittsburgh
Greg
StClair
WRXQ724
Sorry to share Instagram but it’s all I have of two crossings.
Roofus
Swamp
Bronco
Roofus
That doesn't look too bad. I've definitely got clearance for that assuming the water line hasn't risen. I'd imagine it would be lower in Oct/Nov than in May, no?
bear_den_overland
Pittsburgh
Greg
StClair
WRXQ724
this is the link to the gauge. I think when we crossed it was about 2’8” at the gauge for reference.
Reactions: Roofus
Krusty
brian
columbo
Looks fun!!
Reactions: bear_den_overland
Roofus
Swamp
Bronco
Roofus
Necro'ing this post. :)
We didn't end up getting to do the trip last year and went to Overland Expo instead. ha! But we were looking at the end of March as another possibility. I checked in on the water height today for the crossing and looks like it was at 8ft(!!) just a few days ago. The bottom of my door is 22" and my floor board is at 25". I'm assuming any higher than 2 feet and I'm dealing with wet carpets. Might avoid this obstacle.
Reactions: DrRobert
John Bishop
Bishop
Until later in summer, it’s probably going to be a crapshoot for water levels. I went though that area last year. I was by myself, so wasn’t going to risk a crossing. It’s not that much out of the way to bypass.
Reactions: Roofus
Roofus
Swamp
Bronco
Roofus
Is the bypass pretty obvious to get back on the trail?
