- First Name
- Michael
- Last Name
- Gauthreaux
- Member #
12591
- Ham/GMRS Callsign
- W5AZA
I would say I'm still a beginner for off roading, they are 17" wheels with 245/75/17 Goodyear Wranglers. I'll look at a winch, Treds and a recovery kit first I guess, and a stubby antenna.My thought process is recovery gear first.
How experienced are you offroading? Drive it and learn.
Maybe all-terrain tires if the stock ones aren't great (they probably aren't, but fine for most gravel roads, etc.) Are those 17s or 18s?
Also I'd switch out the factory antenna for a stubby. The factory one whips around a lot and chips the pain by the windshield.
I have an air compressor already that I got from O'Reilly's a couple of months ago. And a cheap on as backup.Yep, I agree with @brien on the air compressor.
Before I got my ARB, I used the high output compressor from Harbor Freight (Like $60). Filled up my 35's quickly and lasted a long time.
I wouldn't worry about the lights right now. They should be more than adequate for now.
I do, I opted for the AEV Rack with Side Rails (Around $1300 for both). I didn't like the look of the dom tubing around the sides of my rig.I plan on easy to moderate trails. plan on just overlanding so no rock crawling. Looking to do most things on a budget but dont plan to go cheap just want reliable products. this edition doesnt not come with the locker but has anti spin. largest tire size i plan on at first is 33" maybe 35"s down the road but will see how things go and if trip plans require it. Thanks for the info @GetLost . Do you have a roof rack? and have you done the trails in the Ozark?
Shouldn't need a winch yet. Save that money and use it to get everything else for recovery and new headlights, they are terrible.I would say I'm still a beginner for off roading, they are 17" wheels with 245/75/17 Goodyear Wranglers. I'll look at a winch, Treds and a recovery kit first I guess, and a stubby antenna.
Sent from my Pixel XL using OB Talk mobile app
Will doI.M.O. go with a 2 1/2 teraflex lift with 285/75/17’s. Inexspensivly done & not an overkill & you can go ANYWHERE as needed for off-roading/overlanding. Recovery gear & traction plates also. Check out xbull on eBay. Cheap alternative & work great for mudd & bridging. Get out there & see what your rig is capable of first & find your comfort level & modify from there. To have a very capable rig you do not need to spent 15k. Jeep jku’s are unbelievably capable bone stock. Just my [emoji111]️Cents & good luck with your build. Keep us posted & share Picts of your build.
I have a yaesu vx-7r handheld but looking for a permanent rig radiodefinitely look into a CB or a HAM radio for trail communication
I bought these off ebay too. Haven't used them yet, but they look pretty capable.I'll second the 10-ton x-bull tracks. I've been using them for about a year and they haven't let me down yet
