This 2018 Crux 1600 weighs in at only 1,800 pounds. With independent suspension and articulating hitch, this unit can go anywhere your vehicle can tow it!
The Crux 1600 has an outside kitchen with a propane cook stove and sink. The unit also has an 18 gallon water capacity. Rear slider that will fit most 50qt refrigerators. It’s incredibly capable Off-road and will go anywhere your tow vehicle can pull it. Tons of storage, in sliding lockable drawers. This unit comes fully loaded with a huge annex room that covers the kitchen, a 100 watt folding solar panel that keeps the AGM battery charged up when you're off the grid. Trailer dimensions: L 11’6” x W 5’5” x H 4’9”,Tongue Weight: 220lbs. Weight: 1,800lbs,GVWR: 3,300lbs. Suspension: Independent suspension with heavy duty springs and gas charged shocks. 10” electric brakes with a hand brake on the draw bar, Dual drawbar safety chains Chassis: Heavy duty, off-road, galvanized steel frame. Rims and tires: 15” alloy rims, six bolt pattern and 31” x 10.5” Cooper Tires, with matching spare. Standard 7-pin connection plug. Water Tank: Stainless Steel 18 Gallons with alloy skid plate. Storage: All storage doors have air-tight, waterproof seals and locks
Two jerry can holders on drawbar. Four heavy duty, adjustable, lockable legs
Lights: LED lights throughout trailer, in crucial locations: chef’s galley, electrical panel, refrigeration chamber, LED tail lights. Bed Size: L7’1” x W5’7”. Electrical: 100A/H deep cycle battery, overload protection, two 110V outlets, two 12V outlets, 1000w inverter. Battery is charged by your vehicle when 7 pin style plug is connected, or solar power.360 degree poly block coupling. Heavy Duty Swing Up 10 inch Jockey wheel. Chef’s Galley: Slide out stainless kitchen, with two burner propane stove, sink and electric water pump. Tent: 15oz Coated Canvas tent and ones with an additional extra large annex room. All canvas material is 150z double stitched, waterproof, mildew resistant canvas roof and sidewalls with heavy duty Velcro and zippers. Mosquito proof and UV protected window screens with polyethylene rubberized floor in vestibule and detachable polyethylene floor in annex.
Located in Central Indiana
(317) 443-3064
(317) 443-3064
