SOLD 2016 Turtleback Expedition, reduced price
Red Mtn Gobi
Ivins, UT, USA
Shayne
Jones
Turtleback sold 11/29/20!
It has been nearly 2 weeks since this for sale ad was posted. I appreciate all the views but am anxious to make a deal. Price was $18,500, reduced to $17,500. If you are interested in the Turtleback PM me your offer. I would love to see someone get this and put it to good use.
This Turtleback is in great shape, a bit of pin striping, but no dents. The tent is in great shape, all zippers work, windows are intact and functional. The awning is fully functional and can be enclosed with the included side panels. Cookstove, water pump and water heater are all in full working order. Trailer has been stored indoors out of the elements. If you are not familiar with these campers I have included the full spec sheet below. Trailer is located in Ivins, Utah. We are the second owner.
New reduced price $17,500
Standard Equipment:
Full Steel Trailer 2x3 Perimeter Box Frame, 3500# stub UCF Flexride Rubber Torsion axles, 2750# Springs, 10" Electric Brakes, 16" Steel Wheels, 265/75-R16 BFG KO2 BFG Tires, Forward and Aft Receiver Hitch on Frame, Bedliner Coated Chassis, 0.060" White Aluminum Skin, 2 Side and 1 Rear Compartment Doors w/ Matching Keys, LED Lighting, 11# Propane Tank with Stainless Steel Bracket, Deka Group 24 AGM Marine Battery in Box with Blue Sea Fused Terminal Block, Blue Sea Systems® Marine Grade Electrical Components, 4 Rail Cargo Bar Roof Rack, 2000# Swing Away Tongue Jack with Foot, Safety Chains, 7 Way Flat Trailer Plug Wired to: Running, Brake, Turn Charge Line & Trailer Brakes, Interior Lighting in Cargo Area and Kitchen, 42 Gallon Fresh Water Tank Food Grade, BPA Free Construction, Flowjet 12v Demand Water Pump, Atwood 6 Gallon DSI Water Heater, Exterior Shower, Baltic Birch Pantry Drawer in Kitchen Area, Baltic Birch Slide Out Kitchen with 2 Drawers, 2 Burner Wedgewood Stainless Steel Stove with Stainless Cover by Atwood, Stainless Steel Sink with Hot & Cold Faucet.
Tailgate - Includes 18”x36” brushed stainless steel fold down table, spare tire mount, spare idler hub with greased bearings, Turtleback Trailers Rotopax dual mount.
48"x32" Nose Box, 45" Side Box, 25" Side Box Our Storage Box Set are constructed in house using CNC Laser cut aluminum, powder coated in and out. Doors lined with Baltic Birch inserts and sealed with 3/8" rubber bulb seal that is connected with a steel re-enforced pinch welt.
Includes Blue Sea 1 Battery Disconnect, Blue Sea 6 Circuit Fuse Block, 6 Amp Marine Battery 2 Bank Charger (Shore Power), 10 Amp Solar controller with Voltage Meter.
Options/Upgrades
-Custom Color - Blue
-Max Coupler
-Spare Tire and Wheel
-90 Watt rollable Solar Panel
-2000W Pro Watt Inverter Package
-Additional Grill LP Tank
-1-2 Gallon RotoPax Fuel Can
-RotoPax Deluxe Mount
-23Zero Walkabout 56 Roof Top Tent (comfortably fits two adults)
-Foxwing 270 Degree Awning
-16” Toyota FJ TRD Wheels (3)
-Trasharoo Trash Bag
Specifications:
Exterior Length 11’ 6”
Exterior Width 6’ 2”
Exterior Height 7’
Freshwater Cap. 42 gal
LP Gas Cap. 7.5 gal
Water-Heater Cap. 6 gal
Inverter 2000 watt
Battery Group 24 AGM Deep Cycle
Tires BFG KO2 265/75/16 (3)
Suspension Flexride rubber torsion
Weight 2,470#’s
Hitch Weight 125#’s
Axle Weight 2,345#’s
GVWR 3,500#’s
Cargo Cap. 1,030#’s
Red Mtn Gobi
Ivins, UT, USA
Shayne
Jones
Here are a few pics. Rear is in perfect condition. Right side has one scratch up high, looks like a branch caught it, goes the length of the right side but definitely can be polished out. Left side only has scratches on the hatch door where it looks like a few branches lightly scratched it. Front is in good shape.
Red Mtn Gobi
Ivins, UT, USA
Shayne
Jones
Yes it is still available. Spare tire has never seen pavement or dirt, tread depth is .450”. Not quite a 1/16th of an inch under 1/2”. The other two tires are at .400”. Still a lot of life left.
