Link to photos
New 12x33" 50R15 Cooper Evolution M&S tires with chrome wheels
New wheel bearings, packing, and grease
Heavy duty 14 gauge steel laser cut chassis, powder coated corrosion protection
Side protection bars
2" receiver type tongue and 2" rear accessory/recovery receiver for accessories
Lock and Roll multi-axis coupler for articulated travel on and off pavement
Stainless steel hinges and latches throughout
Textured black chassis and suspension, high reflective white body components
Electric break-away brakes
Gas strut assisted cargo lid that can be opened with rooftop tent up or down
2.5 gallon/11 LB propane tank - Port
2.5 gallon/11 LB propane tank - Starboard
Kitchen with mounted two burner Partner Steel stove and flip down removable cutting board (Starboard)
1, 22" Partner Steel Hard-Anodized Aluminum Griddle
LED kitchen lighting
Storage box (Port)
Nose box for storage and battery
- 1500W inverter and 12-volt outlet
- Dual 225AH 6V VMTanks deep cycle AGM batteries
- NOCO GENIUS G26000 12V/24V 26 Amp Pro-Series Battery Charger and Maintainer
- NOCO GCP1 15A AC Port Plug, 125V Power Inlet Socket, and Waterproof Electrical Outlet Receptacle Box with 16 Inch Integrated Outdoor Extension Cord
- Renogy Rover 20A 12V/24V Auto DC Input MPPT Solar Charge Controller Parameter Adjustable LCD Display Solar Panel Regulator fit for Gel Sealed Flooded and Lithium Battery, Rover 20A
- 400W Portable Mohoo Solar Panels 3x100 watts each
- 1 GoPower MC4 Connector Port
- External 12V port with voltmeter
- onboard 19 gallon BPA free food grade plastic water tank with a battery powered pump/faucet
Mr. Heater BaseCamp B.O.S.S XCW20 Battery Operated Shower System
10 gallon (2 x 5-gallon) gas cans and mounts protected by a skid plate underneath
Maggiolina Airland crank up roof top tent (includes a spare crank) with hard shell and 5" memory foam mattress and interior light
- 1 MAGGIOLINA / AIRTOP changing room
- Roof mounts on top of roof top tent for solar panels
- Aluminum ladder
6x6 Fiamma roll out awning self contained in an aluminum snap shut case
Rear flip down work space platform door
Rear slide out refrigerator storage slider with 12-volt electrical hookup
Interior cargo tie down points
Interior floor rubber mat
Valterra 020106 RV Stabilizer
1 MaxxHaul 70422 48" x 21" Hitch Mount Compact Aluminum Cargo Carrier - 500-lb Load Capacity
1 WILCO Offroad Hitchswing (adds a secondary 2” receiver hitch mated to a swinging arm)
Overall Length: 124″
Overall Width: 68
Main Cargo Box: 40″W x 30″H x 54″L
Side Box: 14″W x 14″H x 54″L
Nose Box: (32″ W + 12″W) x 20.5″ H x 21.375″L
Cubic Capacity: 54 Cubic Feet
Base Trailer Weight: 1100 lbs.
Payload: 1600 lbs.*
Ground Clearance: 24″
Box Material: 14 Gauge Steel
Chassis Material: 2″ x 3″ x .120″ steel tube
Bumper material: 2″ x 5″ x .187″ steel tube
Coating: Zinc primer and powder coating
Storage box (Port)
- Aluminum ladder
Overall Width: 68
Payload: 1600 lbs.*
