SOLD 2004 Toyota Tacoma X-tra cab 4x4 manual transmission Low Miles
Sologeek
PACNW
Truck is available now and is located in SW Washington state.
2004 Toyota Tacoma X-tra Cab 4 X 4. Manual transmission (Stick) 5 speed. Only 109k miles. Clean and clear title in hand.
I have a new clean Carfax report for the truck available.
I bought the truck from original owner. The truck was first purchased from Beaverton Toyota in 2004. So, the truck has always been here in the North West.
Truck is in excellent condition and drives better than new. I have receipts for thousands of dollars of parts and many, many hours of work available.
Never raced or abused and always adult owned and maintained.
NO Rust!
Interior:
Is in nice condition. No rips or tears in carpet or seats. Headliner is tear free and looks nice. Interior lights are all working. The interior has never been smoked in.
Everything works. Windows doors, AC, Heat, All buttons and knobs are in working order.
Wet Okole seat covers (In Pictures). They are black and green to match the truck with a paw print printed on each side because my dog is my best buddy and goes with me everywhere!
Pioneer Avic 5000 NeX stereo with navigation and Bluetooth. (Only factory speakers are installed though. It sounds only meh. I was going to install speakers and amp at some point.) I still have the original head unit if wanted.
I just installed a Uniden CMX 760 CB in the lower center console between the seats so it does not show unless you take it out. I installed 4foot Firestik CB antenna and Heavy duty spring using a high quality CBI off-road Hood mount.
Exterior / Drive-Train
Everything works and is in very good condition.
Paint matched ARE canopy with side access windows (See pictures)
Bedrug bedliner
All the following parts / work was done last summer:
456 Gears front and rear. Ring and pinion install kits for both front and rear.
New CV Axles (Both Sides)
New lower ball joints (Both sides)
Custom Magnaflow exhaust routed for high clearance all of it welded.
Tires / Wheels:
Dick Cepek 255/85/R16 tires with 90% tread. (See pictures).
http://www.dickcepek.com/tires/extreme-country/
Wheels are Konig from FN Wheels Five Star 16X8 +0
https://www.fnwheels.com/new-products/fn-wheels-five-star/
Suspension:
ICON Suspension system Stage 4
Icon Ext Travel Coil overs with Reservoir. Adjustable (I have Icon Wrench to adjust them with included)
Part #58715 if you want to look them up.
http://iconvehicledynamics.com/shop/402-1996-2004-tacoma
Total Chaos UCA's
http://www.chaosfab.com/96-04-Tacoma-Upper-Control-Arm-Suspension-Kit-96500.html
Rear springs are OME Dakar spring packs.
http://toyteclifts.3dcartstores.com/Rear-Lifts_c_186.html
The suspension is very nice on the trail or road. Wheel travel, durability ride quality were my goals. All bushings and ball joints were replaced. Brake lines extended, everything done right with no shortcuts.
I also have all parts / plates and bolts for rear Ubolt flip kit. Tabs and all hardware included. (See picture)
Transmission:
Competition clutch stage 3 clutch and bearing kit.
URD Short throw shifter
https://www.urdusa.com/
LC Engineering performance High Torque flywheel 30LB billet steel. ( I believe this was the 8lb heaver one than stock.)
Part #1052011
http://www.lcengineering.com/
Motor:
Stock except for AFE CAI and optima battery.
I have URD super grip crankshaft pulley Not installed but can be included.
I have new from Toyota upper and lower radiator hoses that have not been installed yet. I was going to do them at the same time I did the crankshaft pulley. Existing ones are in great shape so no I have not been in any hurry.
Also have brand new from Toyota brake and clutch slave cylinders that have not been installed. Existing ones are in very good shape. I just have not gotten around to it.
$19,500 OBO.
2004Tacoma Trail shot sideof truck.JPG 2004TacomaGateKeeper1.JPG 2004TacoSideshotmudtires.JPG good pic front to back.jpg Fronttobackpassside.jpg good pick side from back.jpg IMG_0171.jpg IMG_0168.jpg IMG_0173.jpg IMG_0177.jpg Inside stick.jpg origsticker1.jpg
passint pic.jpg tirepicgood.jpg backoftruck.jpg backopen1.jpg backseat2.jpg backside.jpg CB Uniden CMX760.jpg frontsuspension11.jpg IMG_0159.jpg IMG_0206.jpg IMG_0208.jpg
Thanks!
Reactions: Boort
