So I'm gonna sell the superduty. Didnt think I ever would but I barely drive it. Needing to put a trans in it really drove that home.
So the pros and cons
Pros 2003 7.3 diesel with a 140k miles
Oil changed every 5k at most using rotella t6 and motor craft filter .
Donaldson pretty fuel/water filter.
Sinister diesel coolant filter
Use delo elc coolant
Diesel site dual alt upper radiator hose. Water pump replaced with Ford water pump. Riffraff diesel billet thermostat housing with Ford thermostat. New coolant bottle installed just because.
S&b CAI mbrp 4 inch turbo back straight pipe.
Wicked wheel II installed
Riffraff crossover tube
PHP Hydra tune. Ised the 60hpndaily and 40hp tow only.
Monster white glow plug relay
That's about it for the engine
Trans got a john woods valve body and Moshimoto 37 row cooler to help it along for awhile. Valve body may be able to be salvaged.
Ext.
Recon cab lights, 05-07 harley headlights. Arb front bumper.
08 rear bumper and tailgate with step
Amp research steps
08 mirrors with side markers and turn indicators and heated mirror
AE wheels - 35x12.5r17 toyo at2s with about 10k miles on em max. Load E rating
Suspension Icon 4 inch springs in front with 2.0 icon reservoir shocks
Rear is 4 inch blocks with bilstein
Both front wheel bearings replaced about a year ago with timpken bearings. Replaced all calipers and pads and rotors at that time along with adding steel braded brake lines and fresh fluid.
Inside clarion double din with back up camera. Jl audio speakers miss and tweets. Isspro gauges boost /trans/egts.
4x4 works hubs work and recently cleaned and lubes. Axles a are 3.73 gearing with no issues. All power works
So the cons...
The trans needs to be replaced. It still.goes into gear but is puking out the front
Heated mirror portion need a 12 volt switch.
Clear coat on headlights are pealing.
And the paint clear coat is peeling
Seats are beat up and should be replaced though the power adjustments still work.
Windshield has a crack.
Also it has been in accident. Had it repaired at Byrons auto body in napa.
Asking 8500 as is. Dont want to put it on CL and rather see it go to someone who has time and need for it. Thanks and more pics availabl
One of it clean and the rest after use lol
Ext.
Amp research steps
So the cons...
