I am unfortunately parting with my 4Runner. It has been a labor of love, but I am now in a place where it will not be used to its best capacity. I am in need more of a truck unfortunately. Its built to go places, just add a winch and rock sliders....boom, full blown dynamite rig. I have worked hard on this rig, and have over $16k into it. We can talk about the price like adults, just don't low ball me. We all build these rigs as labors of love. I do "daily" drive it, meaning maybe 50ish miles gets put on it a week. We are currently sitting at 268k on the odo. Anyways, here are the details. Lastly, would consider a trade for a truck, preferably a stock Tacoma, or a 6.0 diesel.
Exterior/Wheels/Tires/Brakes
Removed the running boards
SCS Matte Black SR8 16's
General AT2 265/75/16
Wheeler's Off-Road Brake lines
13WL Tundra Brake Upgrade
Shrockworks front bumper with baja designs led fogs
Shrockworks rear bumper w/swing out and jerry can holder
Shrockworks full skids
Full length roof rack
Interior/Electronics
Alpine CDE-HD149BT with the XM antenna
Kicker CS65 6 1/2" in the front doors
Kicker CS5 5 1/4" in the back doors
LED dome light replacements
Uniden 520XL CB w/3ft Firestik
LED Lighting in the dash
Under the Hood
New OEM radiator/hoses/thermostat
Toyota Red long life coolant
New B&M 70264 Transmission cooler
New idle air control valve
new PCV valve
new plugs and wires
New rear sway bar bushings
Suspension
Icon CDCV 2.5 coilover
Icon CDCV 2.5 rears
OME 861
Built right UCAs
Sway bar end links
New Lower ball joints (OEM)
Outer Tie Rod ends (OEM)
New Sway Bar Bushings Front/Rear
Steering Rack Bushing Kit
Complete rear end rebuild
Parts you'll get with it.
HID Headlight Retrofit
Trans flush/filter and fluid change to Royal Purple
I also have some misc. other things too.
Maintenance
Timing belt/water pump/thermostat-250,413
OEM plugs/wires/PCV valve-251,413
Head gasket-251,413
Rear main seal-251,413
Under the Hood
new PCV valve
new plugs and wires
Suspension
Icon CDCV 2.5 rears
OME 861
Built right UCAs
Sway bar end links
Maintenance
Head gasket-251,413
