I'd be looking at somewhere around $2000 on this one. It's a unibody and rusted frames are hard to live with and a common problem I'm told.I am looking at buying an XJ to build my overland rig. I have found someone interested in trading one for my RTT trailer but am not sure if I want to get such an old vehicle. What is everyone else's opinions?View attachment 133299View attachment 133300View attachment 133301
I have to say I wouldn't buy a xj pre 1991, for all the above reasons and more. Front axle has a vacuum actuator that is very problematic, the brake booster if not upgraded would need to be. Don't get me wrong, I also love my Xj. Funnest vehicle I have ever had. It is a 91' and I have done so much to it the list would be mind blowing. I still have several things to go before I'm done. But if I were to start over and I was going to go with an Xj again. I would get a 98 or early 99. 50% of all the work that you would have to do to the 90 xj is taken care of through the improvements they made in the 98-99 years. 2000-2001 they put a low pinion axle in them and went free on a distributor to coil packs. Also 1999-2001 the heads on them have a major flaw in the casting. So after time a large % of them develop crack.I am a fan of XJs. I have three of them...
Not to say "don't do it", but to make you aware of the potential issues you will need to face: A 1990 is a Renix system. The Renix system can be challenging to diagnose when there are engine sensor problems. It is not that it can't be done, it just requires a different approach. Renix computers don't play like OBDI or II. Very few scanners even talk to Renix computers. A Snap-On MT2500 (aka "brick") is one that will. Alternatively, there is a new tool made specifically for the Renix. Do a search for "Nick in Time Renix" and you should come up with the latest development on that front.
Looking at the one pic offered I will suggest that vehicle probably doesn't allow for much articulation. That looks like a pretty low lift for the tire size. A low COG (Center of Gravity) can be a good thing, but if the suspension isn't properly bump stopped you are going to have tire-fender interference issues. Try to figure out if it has been properly bump stopped. Otherwise you are looking at adding bump stops, trimming fenders or adding lift. And if you go for adding lift you can expect additional issues to crop up. An SYE (Slip Yoke Eliminator) will probably be the next thing (to cure driveline vibrations).
With XJs in general, rust is the biggest issue. Don't buy it without looking at the floor pans. It is probably simplest to look at them from underneath. Feel them with your fingertips. Expect to find some rust over the catalytic converter. What you don't want to find is rust in every singl8e footwell and in the rocker panels. Worst of all is rust in the frame rails.
While you are underneath, check around the steering gear box. Look for cracks in the frame rail. Ideally you will find that someone has already added reinforcement in this area. If they haven't, you should plan to do so.
I would also inspect door hinges where they mount to the body. The driver's door is the most likely problem, but look at all of them while you are at it. The hinges have a tendency to break loose from their welds to the body. This gets worse the heavier the doors are, so a 2 door with power windows/locks/aftermarket speakers is going to have the worst case scenario while a 4 door with manual windows/locks/nothing added to the doors is least likely to have issues. But, add teenagers messing around with things and all things become suspect.
After you look it over really well, only you can decide if it is worth it. Among other considerations, I would ask if you are good with tools. An older XJ (any 30 year old vehicle for that matter) is going to give you plenty of opportunity for turning a wrench. And as to trading your trailer, what would be the market value if you were to put it up for sale? You will have to give that an honest assessment.
For a running mostly intact XJ this price isn't to crazy depending on area. 20 to 30 years of abuse and sawsalls has taken its toll on the XJ population. That combined with renewed interest in the platform has resulted in increased demand with an ever decreasing supply.I loved my last XJ and paid $1,900 for it with 178k miles. A/C compressor did not work but it needed nothing else. The price on that one seems pretty steep even with the mods. As a reference I paid $2500 for my 92 Land Cruiser with 226k miles and it had almost new 33" BFG A/T's on it, no rust, great interior, and not much work needed besides baselining. Both of those were bought in Colorado and prices seem steeper here than other places. That said, I'm from your area originally and know that people really value their 4x4's and the price typically reflects that. Now that 4Runner next to the XJ in the pic for $3500...![]()
I think it all depends on where you live and how much abuse the truck will be subjected too. If you plan to beat it, then I would want a better platform than a unibody unless you are good with fabricating sub frame rails and roll bar cages. The thing I like about them is they are pretty simple to work on I am told. Still think $3500 is too much regardless of scarcity.For a running mostly intact XJ this price isn't to crazy depending on area. 20 to 30 years of abuse and sawsalls has taken its toll on the XJ population. That combined with renewed interest in the platform has resulted in increased demand with an ever decreasing supply.
[/QUOTE
Very true. I have seen a bunch of low mile very clean xj's selling for around the $10k mark, which I think is crazy but what ever. Luckily there were millions of them sold in the US but there are a lot of them that have met an early grave due to rot or abuse. unibody stiffening kits can be bought for very reasonable prices now, right around $300 front to rear if you shop around. I just did the center section on a friends and bought them online for $150 shipped. The 1/8" stuff is more then sufficient unless you plan to do jeep speed or baja 1000 kind of stuff.
