$17,000 2020 teardrops NW ranger offroad
STPICKENS
Evansville, WY, USA 82636
SHAUN
PICKENS
We are selling this wonderful Teardrops NW Ranger off-road trailer. We had this custom made in jan-feb of 2020 and still have the build pictures from it. We bought this for a trip to Alaska that didn’t happen. It has about 6k miles on it. Its been garage kept it entire life. It tows like a dream. You totally forgot its back there. This is a massive upgrade from tent camping. Super comfortable inside and warm in the winter with the insulation we had installed. The kitchen is a great place to prepare a wonderful meal while being covered from light rain. The interior is plant roomy enough for taller people to lay down and be comfortable in. The mattress can be used as a couch as well for added comfort if you would like to have a mini living room during the day. Pair all this with a roomy 8’x8’ arb awning and you don’t need trees for shade. You got it all. This has seen dirt roads in its life and it handles them really well. It’s a go almost anywhere trailer that will get you out into the most desolate locations or to your nearest koa. Wherever you go someone will compliment you on the trailer and ask about it. The only reason why we are getting rid of it is due to us not using it enough. The batteries have been properly maintained and trailer has been ventilated when not in use. It still smells like wood inside. We don’t need to get rid of it but I would love to see it go to a good home that will show it the world...
RTT NOT INCLUDED IN PRICE….
RANGER 5’x9’ 1850lbs
BLACK POWDER COATED 2x3 FRAME WITH WALL SUPPORT TABS
3500LB TIMBREN AXLE-LESS SUSPENSION
12” TRAILER BRAKES
jug
Fully boxed 2” x 3” steel frame. Other standard frame and body features include:
* Black powder-coated tube frame and fenders
* Timbren Independent Axle Suspension 3500lb
* 2” ball hitch (highway) or Max Coupler Receiver (off-road), plus safety chains
* Diamond-plate front rock guard
* 15” steel wheels with 30x10x15 radial tires (Highway); BFG All terrain KO2 (Off-Road)
* Tongue jack with wheel for easy maneuverability
* Leveling Jack stands on rear corners
* Trailer brakes (requires brake controller in tow vehicle)
* 2” hitch receiver (for accessories only)
* tri-fold foam mattress
* Fully insulate walls and ceiling (upgrade)
* 13-speed Fantastic Fan with remote and rain sensor
* Two locking black doors with screened windows
* Multiple interior cabinets options with brushed nickel knobs Cadence with custom twin door cabinets
* LED lighting
* Linoleum flooring
* Electrical outlets (12V, 110V, USB ports, and voltage meter)
* 5-gallon Igloo water jug
* Formica countertop
* Electrical outlets in cabin and galley (12v, 110v, and USB ports)
* Twin 6v batteries (upgraded)
* WFCO WF-8735-P Black 15/30 Amp Power Center
* LED porch lights
* Marine-grade shore plug
* 7-pin trailer connector
* LED brake, tail, and turn signals
* Expanded steel cargo area (add on)
* Custom exterior powder coat roof, sides, hatch
* Round windows (upgrade)
* Dometic slide out fridge with 500lb slide
* Triangular diamond plate box (upgrade)
* 10LB propane tank with side mount
* Arb 2500x2500 awning with room
* Roof cross rails
* Zamp 90 watt solar panel
that's actually not bad for a 20. teardrops are solid if you're just doing light trail stuff. idk what engine it's got but make sure the suspension can handle whatever you're throwing at it. i'd check the maintenance history tho, some of those get beat on pretty hard. what kinda trails you planning to run it on?
