FOR SALE Turn-Key 2024 Toyota Tundra Premium Overland Platform
Thunder Snow
Portsmouth, NH, USA
Traci
Clever
PREMIUM TURN-KEY OVERLAND EXPEDITION PLATFORM
2024 Toyota Tundra Limited i-FORCE MAX Hybrid 4x4
Complete Custom Build by OK4WD (June 2024)
Odometer: 10,100 miles (Tested, fully sorted, and meticulously maintained)
Maintenance: Single-owner, zero accidents. All standard vehicle service meticulously performed at the local Toyota dealership.
Asking Price: $93,500 (Or Best Offer)
Total Documented Build Investment: $125,000+
**The original Toyota factory window sticker (VIN: 5TFWC5EC3RX007031) and the line-itemed OK4WD master service invoice are attached.
For personal reasons, I am selling my complete OK4WD custom-built overland setup to move to a different platform. This is a remarkable opportunity if you are looking to get into a top-tier Toyota full size Alu-Cab overland system. This vehicle was handed over to the master technicians at OK4WD in June 2024 with just 860 miles on the odometer and expertly transformed into a no-expenses-spared, premium four-season overland platform with zero compromises—perfectly sorted yet entirely ready for further personalization.
Built on a highly optioned Crew Cab layout with the 6.5-ft Long Bed, this rig seamlessly couples the immense power of Toyota’s flagship hybrid twin-turbo powertrain with the ultra-premium utility of a fully integrated, 2024 Alu-Cab Alu-Cabin Canopy Camper. Upgraded with an elite Elka 2.5 reservoir suspension, Old Man Emu heavy-duty rear coils, a comprehensive sPod touchscreen power distribution matrix, and a massive Goal Zero Yeti PRO 4000 ecosystem, this platform is turn-key and prepared to self-sustain off-grid indefinitely.
Skip the 6-to-12 month procurement backlogs, freight transit delays, and multi-week builder queues. This exceptionally low-mileage, world-class overlander is thoroughly tested, professionally sorted, and immediately available for your next transcontinental expedition and further customization.
Base Vehicle Specifications & Premium Factory Options
* **Powertrain:** i-FORCE MAX 3.4L Twin-Turbo V6 Hybrid delivering 437 hp and 583 lb.-ft. of torque, paired with a 10-speed electronically controlled automatic transmission.
* **Exterior Color:** Premium Wind Chill Pearl with matching color-keyed accents.
* **Interior & Comfort:** Gray SofTex®-trimmed, 8-way power-adjustable heated and ventilated front seats with driver's seat memory.
* **Premium Factory Upgrades Included:**
* **TRD Off-Road Package:** Electronically locking rear differential, Multi-Terrain Select (MTS), Crawl Control (CRAWL), Downhill Assist Control (DAC), off-road front skid plates, and unique TRD interior accents.
* **Limited Premium Package:** Premium LED headlights and Trailer Backup Guide with Straight Path Assist.
* **Limited Power Package:** Qi-compatible wireless smartphone charging and dual 400W/120V AC power outlets (rear seat and bed-mounted).
* **Premium Tech & Audio:** Flagship 14-inch Toyota Audio Multimedia touchscreen paired with a factory-upgraded **12-speaker JBL® Premium Audio system**, Panoramic View Monitor (PVM) 360° cameras, and Blind Spot Monitoring.
* **Panoramic Roof:** Power tilt/slide glass panoramic roof with a power sunshade.
* **Premium Cab Accessories:** Included in the sale are custom, vehicle-specific **WeatherTech floor mats** for maximum element protection and a complete set of **custom-fit premium thermal window covers** providing total cab blackout insulation and absolute climate control.
Premium Suspension, Wheels & Running Gear Matrix
To safely handle the payload of the Alu-Cab camper while maintaining impeccable on-road dynamics and high-speed off-road tracking, the entire chassis was upgraded with heavy-duty components engineered for transcontinental travel.
* **Suspension:** Elka 2.5 DC Reservoir Coilover Kit (22+ Tundra specific) with adjustable dual-speed compression damping to handle continuous weight with supreme control.
* **Upper Control Arms:** BDS Heavy-Duty Upper Control Arms (UCAs) to correct suspension alignment and geometry while maximizing clean wheel travel.
* **Rear Suspension:** Old Man Emu (OME) Heavy-Duty Rear Coil Spring Set (2864) specially rated for constant-load overland builds, completely eliminating rear sag.
* **Geometry Alignment:** OME Gearbox Packer (JWGK03) and welded steerstop extensions to prevent tire rub and ensure perfect factory driveline alignment.
* **Tires:** 5x BFGoodrich All-Terrain T/A KO2 (LT295/60R20 E-Rated, 10-ply construction) mounted on the OEM wheels (includes full-size matching spare).
The Alu-Cab Alu-Cabin Living Ecosystem
The centerpiece of this build is a premium 6.5-ft Black Alu-Cab Alu-Cabin Canopy Camper, professionally sealed, bolted, and integrated directly into the Tundra's bed via a model-specific precision fit kit.
Climate Control & Four-Season Comfort:
* **Dickinson Marine P9000 Propane Fireplace:** Premium, dry-heat marine fireplace kit professionally mounted with a custom GP Factor surround, custom exterior chimney vent, and a dedicated low-pressure propane line system.
* **Propane Infrastructure:** 10LB LPG Cylinder mounted securely via an Expedition Essentials Quick Bottle Mount, complete with a professional propane fill and leak test.
* **Ventilation Matrix:** GP Factor Pressure Vent with Cover Kit to keep trail dust out of the living area while driving, plus custom integrated window screens / Mozzie Nets on all doors fastened securely with heavy-duty rivets.
* **Bedrug Insulation:** A full 6.5-ft BedRug system installed beneath the living floor for exceptional thermal management and underfoot comfort.
Water, Shade, & Utility Infrastructure:
* **Onboard Water Storage: Alu-Cab Water Tank with an inside mounting kit, paired with a full-size adapter kit. The water system features an integrated faucet cleanly routed to the rear for rapid access.
* **Shower/Privacy: 23 Zero Kestrel Shower Cube cleanly mounted via custom-adapted brackets (Shower Cube to Icarus mounting kit) for a rapid-deploy exterior privacy enclosure.
* **Shade Matrix: Alu-Cab 270° Shadow Awning (Left Hand Side) deploying in seconds, anchored by heavy-duty brackets, a wind deflector, an integrated Shadow Awning Gutter Kit (to eliminate drips between camper and awning), and a dedicated Awning Storm Kit.
* **Interior Modular Utility: Fitted with an Alu-Cab Table and an integrated Table Slide, a GP Factor Folding Stainless Tailgate Table, and heavy-duty rear door Molle plates for gear organization.
Advanced Electrical, Solar & Power Management
This rig features a professional, marine-grade electrical system designed to run high-draw appliances completely independent of the truck's starter battery.
* **Primary Power Station: Flagship **Goal Zero Yeti PRO 4000 LiFePO4 system. Sale includes the premium **Escape Drivable Kit** hardware, enabling rapid alternator charging from the Tundra's high-output engine while driving (note: alternator line is not currently connected to the truck's engine bay alternator).
* **Solar Integration: Roof-mounted RedArc 200W Fixed Solar Panel installed on Alu-Cab 1450mm load bars with low-profile feet. Wired directly to the Goal Zero charge controller using premium 5-ft Anderson to MC4 cabling.
* **Distribution & Controls: sPod BantamX Touchscreen Power Distribution Management system with a 36-inch battery cable layout. Features a custom SCS Alu-Cabin Power Board cleanly hosting the sPod controller, sPod screen, and the Goal Zero remote display.
* **Expedition Lighting (Dimmable via sPod Touchscreen):
* 2x Baja Designs Squadron Sport LED Light Pods (Work/Scene Pattern) mounted on the camper sides.
* 2x Baja Designs Flush-Mount Angled Squadron Pro LED Light Pods (one configured as a camp side-light, one integrated directly into the factory reverse gear trigger feed).
* **Auxiliary Power & Fans: 2x 12V Blue Sea Systems Power Port Sockets distributed front and rear of the bed for flexible accessory power. Includes a Sirocco cabin fan.
* **OEM System Integration:** The factory rear tailgate camera was professionally uninstalled and cleanly relocated onto the Alu-Cab fitment kit to seamlessly preserve Toyota's 360° Panoramic View Monitor (PVM) system.
Verification, Documentation, and Delivery
This vehicle has a clean New Hampshire title in hand, has zero accidents, and represents an incredible opportunity to step into a turn-key overlander today while saving over $32,000+ in build capital and months of fabrication lead times.
*Serious inquiries only. Please reach out via direct message to schedule an in-person viewing or a private digital walk-around video call.*
  • 2024 Toyota Tundra Window Sticker.pdf
  • OK4WD Tundra FINAL_Invoice_o-534039_05312024_R01[33].pdf
Reactions: TsovTov_bbb02a
