Tire Question
LLopez
Seattle, WA, USA
Luisa
Lopez
Hi All.
I’m brand new to this group, so hello!
I’ve just bought myself a Tacoma and want to get some burlier tires than the standard all weather tires it came with.
So without getting a lift, can I go up in the tire size ? Or maybe should I just go for an on/off road tire but the same size?
Thanks everyone!
Reactions: M Rose
Rose
W7FSB
US ARMY Retired
Hi All.
Thanks everyone!
Talk to Les Schwab Tire Center. The people there are very knowledgeable... you should be able to go up one or two sizes above stock without issue. But without knowing what size tire you are currently running, hard to give you any specifics.
As for tires them selves, several of us are really happy with our Maxiss Razors which are a light M/T pattern. They do ok in sand and mud, but really excel in snow. (Which for me here in the northwest is what I look for when purchasing tires).
Rose
W7FSB
US ARMY Retired
Ok super was thinking of going to them and have a looksie!
Thanks so much!
I use Shwabbs because their road side assistance here in the Northwest is by far the best. I was narrowing a friend’s Snow Machine trailer when a tire blew about 100 miles in the middle of no where. I called them up, told them my tire size. And they drove out with both a new tire and a spare. They charged me for the tires, but not for the install or the road trip.
Second story... several years a go I bought a set of tires from another company because they were on sale. 2 weeks later I had a flat... I aired it up and took it back... the company refused to look at the tire... a few weeks later the tire went flat to the rim, I called them up to come put air in my tire so I could take it back to them and purchase another tire. They never showed up. Then after dealing with this for 4 years, I stopped into Schwabbs to get a set of chains. The tech noticed the tire was low, and asked if he could fix it... I jumped on it and said yes... 15 minutes later tire was mounted back on the rim with new valve stem... the valve stem apparently hadn’t been installed all the way. Any ways I was back on the road and money spent was for the tire chains... after that I will always use Schwann for all of my tire and alignment needs.
Reactions: LLopez
MarcoM
San Francisco, California, USA
Marco
Maga
TBD
Hi All.
Thanks everyone!
May also want to take a look at the Tacoma forums to see what other with similar vehicle to your are running. Costco is also great tire option once you find out what you want to run.
@M Rose has a great point though on road side assistance; Shwabbs has great road side assistance in PNW. Wonder if Costco's road side assistance is national or restricted to local where tires were purchased. I got my K02s from Costco and travel to PNW and other western states often enough that would be good to find out what my coverage is. Hmm, time for an inquiry.
Billiebob
earth
Bill
So, a very open ended question. What year, oprion Tacoma? Tire size is a wild card. Toyata spends millions of $$$ coming up with the correct balance. Generally yeah sure you can do anything within 10% of those engineered spacs. BUT upsizing the tires will have very few positive performance plusses. Guaranteed you will lose MPG, you will lose passing performance, you will increase stress beyond what the factory intended. You need to ask beyong "ego" are there any performance gains because yes if you address the extra driveline stress, if you accept worse mileage, range, you can do anything. But look beyond joining the club. Look at the goals YOU have. Decide on the best way to get there. Bigger tires are not the holy grail or the manufacturers would all offer factory 44s.
The guarantee is bigger tire will hurt fuel economy, will hurt braking capability, will add stress to all mechanical components, will hurt passing ability, will hurt acceleration, will make it harder to climb over that log, rock, will affect the life of your torque converter, clutch. Yes you can overcome some of those negatives with a regear, but not all of them. WHY do you want bigger rubber? I have seen sooo many vehicles on virtually stock rubber do the incredible I rate tires like boobs, really who cares......... or penises.
And that is not to say I am against tire size, I've had F250s with 40s, a YJ with 33s, a TJR with 35s, I'm just saying BIG tires are not the holy grail unless you win the lottery. Any bump within 10% of factory is not going to kill the bank account but will it actually add capability. I say likely NO. North America is obsessed with bigger. But watch the reat of theworld. We are the anomoly.
Oregon_trail
Medford Oregon
Micah
White
So personally I’m not a fan of les Schwab mainly cause a lot of the time if a little trimming needs do e they won’t or can’t do it. I’m a bigger fan of smaller shops or shops use to working on 4x4s but that’s just personal preference.
Rose
W7FSB
US ARMY Retired
I’m going to have to disagree on all counts... we went up 2 tire sizes on our 04 4Runner, gas mileage stayed the same, top speed stays the same, heck even acceleration can’t be felt... breaking improved, but probably due to the different tread pattern. Picked up a little noise, but that’s to be expected when going from a street slick to an aggressive tread. It no longer struggles to climb the logs or rocks. If over sized tires are so bad, why do the tire companies make them... I run over size on all my rigs btw... nothing to huge over size... most extreme is the Bronco going 3 sizes above stock... but it can handle up to 33” tires (4 sizes above stock) before needing a lift,
axles, and reinforced TTB...
Reactions: LLopez
Rose
W7FSB
US ARMY Retired
Get the small shop to do the trimming... the road side service is bar far the best in the industry. Where else can you run a tire flat to the point of sepperating the tread from the side wall and still get a free tire 6,000 miles later?
Reactions: Oregon_trail
Oregon_trail
Medford Oregon
Micah
White
I haven’t personally had that experience myself. Only times I’ve used them is when I’m in a pinch and usually I get drug over the coals it feels like for tires. Granted there service is amazing I just thing my money goes farther elsewhere and if you carry a spare you probably domt need that road side assistance.
Oregon_trail
Medford Oregon
Micah
White
I’m also the guy who gets flats a lot! Like I was averaging 2 flats or blowouts a year for a minute.
Reactions: M Rose
Oregon_trail
Medford Oregon
Micah
White
Granted I have a Ram not a Tacoma but I went from 33s to 37s with no loss in performance. The only thing I need to do is get my speedometer corrected cause that being off effects where it shifts. I can still get 20mpg good acceleration and braking and the bigger tire definitely helped my wife’s comfort in the desert trails this week as. Climbing up a cliff side.
Reactions: M Rose
Rose
W7FSB
US ARMY Retired
Funny thing is... out of all the tires I ever punctured... I was on asphalt for all of them. Every time I needed RSA I was driving a barrowed rig or trailer, and used my Schwab account to get the RSA... yes they are more expensive, but I have noticed the more I buy from them the better the price is next time... case in point. I spent 1800 on a set of Maxxis Bighorns for the Bronco. 6 months later got the same size Maxxis Razor Tire for the wife’s 4Runner and only spent 1200... and the Bighorns were on sale when i bought them, while the Razors were 100 more per tire. So go figure (shoulder shrug).
