Up for sale is my 1996 FZJ80 with Factory Triple locking differentials with 263k miles. The unicorn off-road is here for the taking. I bought it in 2015 with 243k miles from a fireman. Up until this last April it had a 2.5 OME. I didn't like the ride as it was installed by the PO. I replaced the lift with ICON remote reservoir shocks for a 4 to 6-inch lift and matched to Dobinson 4 inch lift Flexi Coils. The coils are a dual-rate coil meant to use the added length of the shocks for down travel while still staying seated in the coil buckets. It now rides very nic like the factory softness when new but with the added ability to soak up deep hits with bottoming out and hurting. Also, I added a front tube bumper made by a local Landcruiser shop in Sacramento. Stereo changed out to an Android 7 inch double-din deck that does phone mirror. It currently has the stock wheels with 33 Goodyear Wrangler Duratrac MT tires with 35k miles left on them. I did use 37's on it for a little bit and it rubbed with off-road articulation. It would need some fender trimming. 35 's do not rub with full articulation. To many landcruisers in the family and I have moved on to a more high-speed trail running with a full-size tundra. $12,000.00 O.B.O
Maintenance performed over the last few years is:
Oil change every 2000 miles with full synthetic
Tranny fluid filter change 6000 miles ago
Differential fluid change every 5000 miles
heater hose changed at 244k miles
front axle redone just 1500 miles ago
Radiator changed at 243k miles
Radiator Flushed at 260k miles
Rear Discs and Pads Replaced 1500 miles ago
Added:
Icon Remote resi Shocks 4-6 inch
Dobinson $ inch Flexi Coils
Slee Sway bar blocks
Slee front Raduis control arm bushings
Android Stereo
Front tube Bumper with Winch Plate
24 inch LED front bumper Light Bar
HID front low beams
All Interior removed and Rhino liner sprayed on the floor
Carpet cleaned while removed
Carpet recolored to Black
Added 8mil insulation under the carpet to quite and control heat better
Added monster Deep Cell/Starting battery with 150 amp hours 6 months ago
Slee bump stop extensions
Removed:
Front fender flares
Underseat heater (transferred to much heat to passenger seat)
Underseat heater radiator liness removed (dependability)
Top roof rack ( Platic mounts so old they broke)
Broken:
Front Driver Seat recline switch has no button but still works
Driver seat leather torn on all landcruisers
Passenger seat does not slide forward and back (gear broke)
I had some other components on here but they got moved to my Jeep Rubicon...Sorry
Added:
Android Stereo
HID front low beams
Removed:
Front fender flares
Broken:
