I currently have a 4.0 in my 2000 Jeep Cherokee. I was wondering if I could rip out the computer and put in a carbureted 4.2 like I had in my YJ. In Massachusetts I only have to pass safety not emissions.
I haven’t seen anything from Holley on the rail system.Why not build a stroker out of the 4.0 and put a much better EFI on like something from Holley?
I honestly am learning about all this. My YJ was great with the 4.2 I had a tj with the 4.0 and always felt that the 4.2 had more power. Do you have any recommendations on books to read to help me. Unfortunately I’m doing this late in life. I looked on the Holley site and didn’t see anything for a XJ.EFI is better than a carb in every way, more reliable, less maintenance, more accurate fuel metering, cleaner burning, better throttle response and the engine itself will last longer as a result of less fuel dilution of oil and less washing of the cylinder walls. Those are facts, you are taking a significant step backwards by ditching a well operating fuel injection system. Having owned and driven 4.2 and 4.0 Jeeps I honestly don't know why you wouldn't stick with the 4.0. And yes I have experience tuning and building carbed engines. Honestly the only reason to run a carb is if you are trying to stay period correct for a project, or to just get something going, as building a carbed set up is cheaper and easier.
So heres the deal, the 4.2 is quite a bit different. Their torque curve is substantially different, they make torque at about 1000rpm less if memory serves. This means it will feel more powerful. The 4.0 has a different head design that allows it to deliver more power across a broader rev range. It feels less torquey because it's delivery is more linear and it is a higher revving engine. To get the most out of the 4.0 you need to run it between 3k and 4k rpm, where as the 4.2 is happy between 2k and 3k.I honestly am learning about all this. My YJ was great with the 4.2 I had a tj with the 4.0 and always felt that the 4.2 had more power. Do you have any recommendations on books to read to help me. Unfortunately I’m doing this late in life. I looked on the Holley site and didn’t see anything for a XJ.
Traveler II
To Add, I should say that TBI really isn't much better than a carb. My comments are specific to port fuel injection systems with one injector by cylinder.
all of this....^^^
plus fi will also start way better in extreme cold, will run the same at 0 ft or 8000 ft, fuel starvation off road is completely eliminated and drivabilty is vastly improved.
all of my vehicles have been carbed except for the two i have now. would never go back to a carb except as dilldog states, for a period correct build.
my '90 K1500 is tbi, which really is a little above a carb, but deadnuts reliable. 30 yrs, 400 00 kms with one "rebuild" which consists mostly of gaskets and seals and is easier to do than rebuilding a carb.
my '85 K30 was stock intake with a quadrajet, then a edelbrock intake and holley 750, last 18 yrs has been edelbrock port fi, and there is no comparison. with fi, i just reach in and turn the key- fires up and idles perfectly just like a newer vehicle, no throttle pumping, no choke to play with, no stalling out.
same truck, 2 carbed versions, one fi version, you'll never convince me a carb is superior...
I have ridden in a CJ5 with a built 4.2 and it felt like a V8. So I get it.
With that said,, here is an article/video on Powernation about building 4.0 to produce 242hp. They use a cam, new head, and fuel injection from Fast. Rebuilding a 4.0L Jeep Straight Six to 242HP
