Programming HT ham radio
Mrprez
Wildwood, FL, USA
Kennedy
KJ4WMZ
My question is not about how to program my radio, my question is what frequencies should I program? I’m thinking NOAA, GMRS receive only and a bunch of simplex channels and leave room for repeaters? My radio, TYT UV-88 has 200 channels. How should I divvy these up for best coverage? What am I missing? TIA.
JeepingMike
Greencastle, PA, USA
Stern
KB7THL
USN Corpsman Veteran
I typically put a group of my local repeaters in first, then a group(s) of repeaters in next common areas of travel, then simplex frequencies, then other stuff like GMRS/FRS receive, MURS receive, NOAA (if the radio doesn't have a function for weather channels), local fire/EMS dispatch receive (I'm a Paramedic), etc. If the radio has banks or groups, I separate these groups. Since I use RT Systems software for my HTs, I build and save program files for travel destinations as needed or for regular travel areas with similar layouts as well.
Reactions: Mrprez
RoarinRow
Elk Grove, CA, USA
Rolando
Nispiros
KN6JJS
I put favorites on top, e.g. US: Ham:146.460, GMRS:15, Open Ham Channel, Weather, Local Fire and Emergency, then several repeaters in the areas I think I might travel to, then all the remaining GMRS frequencies, APRS, and ISS just in case.
Reactions: Mrprez
Mrprez
Wildwood, FL, USA
Kennedy
KJ4WMZ
What do you do for simplex channels? I’ve seen img files with rows after rows of channels. Do you program channels from 2m and 70 cm? What spacing is commonly used?
JeepingMike
Stern
KB7THL
I program the national simplex calling frequencies for 2m and 70cm (my radios are dual band) and a couple of locally used others (creating options for quick use in other areas as well). Of course I can add other simplex frequencies from the keypad if a situation calls for it.
Reactions: Mrprez
Oranger
Hastings, MN, USA
Dylan
Lee
KE0ZAU
Here is how I laid mine out: Weather channels, 146.520, 446.000, 145.5625, local repeaters, nearby repeaters, places I see myself going in the near future repeaters.
