Powering a fridge in a diesel truck
Cummins_Overland
Fairfield, CA, USA
Bradley
Davidson
What size did you go with? I’m torn between the 150 and 400
I went with the 400, according to their site the 150 isn't really designed to power a fridge. Also wanted something that was portable and could be charged off of the vehicle the 400 met all the criteria.
Laud
Southeast Arlington TX
Laud
Maroney
-KG5QHC-
Air Force and Army
I would personally step up your choices in fridges.
the unit you referred to appears substandard.
Quality typically starts at $5-600 due to efficiency and safeties built in.
My old ARB allows me to set the shut off at a voltage level.
Saying this, as a factory dual battery diesel owner that has wiped out his batteries with a fridge.
Near perfect world would be a set of stand alone batteries with an efficient charge controller and overkill on the panels with a quality fridge, freezer.
buying ice sounds expensive now....replace two large batteries after walking for help. Ice is cheap!
Reactions: Salty4Life
