Powered water can Update 2/11 for new pump and battery.
This is one of the projects I've had on my list for a while. I wanted a water can I can use as shower, washing dish's or whatever.
All the ones I saw didn't quite fit what I needed so, here's mine.
Pic first then parts list and description.
Parts list
1. Scepter Can lid
2. Submersible water pump
3. Small 12 volt battery
4. Anderson connectors (2 red 2 black)
5. Quick release fitting (if needed). Lid side Hose side
6. Small Gland nut (if needed). Link is for a box of them. I have a bunch so I didn't buy any for project.
7. ½” clear tubing
8. Stainless hose clamps
9. Zip Ties
10.Small switch (if needed)
11.Small LED (if needed)
12. Small box for battery (if needed). I had a few of these left over from another project.
13. Velcro
14. Spray nozzle. Home Depo garden section.
First was drilling a hole and mounting the Quick release. Then a hole for the wiring. I used a gland nut for the wiring but if the hole was drilled tight, it wouldn't be necessary. Cut tubing to length, mount pump and run wire. The pump comes prewired with THREE wires. The colors are Yellow, Blue, brown. The Brown and Blue are cut and tinned. I used the Brown for Pos and Blue for neg. It actually didn't seem to care which way I wired it.
Once the wire was through the lid, I cut it down to where I had enough to plug into another battery box with Anderson connectors. As you can see, I have covers on my Anderson plugs. I got those off Amazon when I ordered them last. This is the first time I've used them. Zip tied the wire and installed the clamps.
Congratulations, your halfway there.
Next was the Battery. I opted for a 1.8AH Lithium. I wanted it small so I could attach it to the side of the can. Its on a Velcro tab so I could take it off to charge. The battery is rated to 14 volts. I literally just hooked it up to my trailer battery and left it there for 12 hours (forgot to unhook it). The charged voltage matched my 12.3 trailer voltage and it didn't blow up.
My battery came with a built in on/off switch and led. That told me, the battery was smaller and inside its own box. I wanted better access to the switch so, I opened the box. The actual battery was a bit smaller and was two 6volt Prismatic cells. Not bad.
The battery switch was on the side, I wanted it top and it was a bit awkward. My original plan was, remove it, put it in one of my project boxes with my own switch and light. Fortunately I was able to use both and didn't have to buy anything. At this point you have two choices, mount it anyway (nothing wrong with that) or get a battery with a better located switch.
Here's my battery pic's. I didn't get one of the battery in the original box. You can see it in the link. The battery would fit in my plastic box but I would have had to cut the mount posts off and glue the case together. I notched the lid for the switch, drilled a hole to see the light and a hole for the wire. Added the Anderson Connectors and Velcro.
Test
Final Thoughts.
The pump could be more powerful. Its actually on par with the others I've seen. I ran it long enough to pump the water can half way with juice left in the battery. I didn't anticipate having to mod the battery but I had the extra parts so no big deal. You could save a bit of money by not installing quick connects and do something else for the connectors. You could even get an inline rocker switch to control it.
Over all I think it will work just fine.
UPDATE
Been using this for about a year. The only drawback has been water flow. I finally found a good pump (took 3). This one also upgraded the battery pack to twice the size. I still velcro it to the side but it's a bit heavy. It "stays" in place but I need to make a holder of some kind (OCD is a pain).
Output is great and the battery hasn't gone dead on me, I do charge it between trips though. I cant give a good estimate, I've never killed it.
I cant give a part number on the battery pack. I cant find it in my Amazon orders
New Pump Number here
The spray goes out about 3 feet and the stream (bad picture) about 10 feet. Way farther then the old pump.
Pictures
cgrest
Hey. Thanks so much for posting this. I just joined Overland Bound this weekend as I have been looking into what to do for a water storage and pump setup. Currently building a camping outfit for my Ram 1500 and this is absolutely perfect. I just need to decide on whether to use a Scepter 20L or a Reliance Aqua Pack 20 L water can based on the area it can fit.
Its still working well. As I mentioned, the pump is the key. All three pumps I used had about the same spec's with the German pump being the only one that actually had the rated output. I still haven't killed the battery pack and only charge it when I remember to.
The only change I've done since the writeup is I added Velcro straps to the battery. This way I can "tie it" to the water can handle and use it on my rear can rack.
cgrest
I have a Jackery generator and thought about using it to power the pump since it will be close to the water storage. I can either use the car plug-in or an AC to DC adapter. But I would like to have an off/off button for the pump as well. The battery is a nice idea too though cause it makes the setup portable, so that is something I will consider as well.
Top
