The time has come to make the move to a family-friendly vehicle. Two seats just ain't cutting it any more. For sale is my beloved 2004 TRD 4x4 V6 Xtracab Tacoma. Purchased in 2012 with 87,000 miles, this truck has been well cared for and upgraded. Currently has 200,834 miles on it and I wouldn't hesitate to jump in this truck and road trip across the country. I actually just returned from a 10-day, 2500+ mile trip down to Southern California and back with zero issues. It's ready to go. Sold as-is and ready to go. All you need is your camping gear, clothes and some food. Normal wear and tear to paint and interior due to age/mileage but not abused.
Check out the build thread for detailed information over the years: https://www.tacomaworld.com/threads/nwxpdtn-04-trd-4x4-xcab.265751/
Asking: $16,999
Located in Snohomish, WA (98290).
I have a detailed spreadsheet that lists maintenance/upgrade dates & mileage, available upon request for serious interested parties. Title is clean and in hand.
Comes with thousands of dollars of goodies:
OME suspension
Camburg UCAs
Retro-fitted HID projector headlights
Blue Sea dual battery setup
Rebuilt stereo system, bluetooth headunit, speakers + subwoofer in custom enclosure
Warn winch (M8000 + synthetic line)
Factor 55 link
Canopy
Prinsu roof racks
ARB awnings
Rotopax
Water pump
Rear sleeping/gear platform
Too much to list!
See below for overview of upgrades:
Rear differential breather mod
Intake resonator delete
Steering wheel shaft tack-weld
Grey wire mod
Pioneer DEH-P9400BH
Auxiliary fuse block (Blue Sea 5028)
Deckplate mod
Transmission cooler (B&M SuperCooler 70268)
Debadge
Tekonsha Prodigy P2 brake controller, 7-pin + 4-flat adapter, wiring
Tint windows (Elite Tinting, 12708 Washington 99 Everett, WA 98204)
Clear corner marker lenses
Huskyliner floor mats
LED map/dome light replacement
Projector retrofit (Mini D2S Stage III from The Retrofit Source) - TacomaWorld group-buy
Black grill assembly
Mini maglite mount in center console
Bushwacker tailgate cap (P/N: 38502)
Powercoat rear bumper and bed tie downs - Hell Yeah Custom Coatings, Kenmore, WA
BPV adjustment bracket (B.A.M.F. product from TacomaWorld)
Redline tuning hood struts (Plus kit)
Tundra brake swap - 13WL (231mm) - (Raybestos reman calipers, Hawk LTS pads, Brembo blank rotors)
Stainless, extended brake lines (Wheeler's Offroad)
Auxiliary backup/reverse lights (Hella tractor lights + OTRATTW switch)
CB radio install (Cobra 19 + 3' Firestik)
OME full suspension kit (881 coils, Nitrocharger Sport shocks, Dakar rear leaf pack, 10mm lift enhancer + shipping)
Camburg UCAs
Konig Countersteer 16x8 wheels + lug nuts
Low Range Offroad U-bolt flip kit & shock relocation mounts
Clearance front fenders
Paint calipers and drums
Magnaflow 18" muffler, new tailpipe and hangars
Derale power steering cooler, new PS fluid
Wheeler's "Super Bump" bumpstops, front
Energy Suspension polyurethene steering rack bushings
Re-wire factory flat 4 pin - 7/4 pin harness due to water damage/corrosion (Curt #57674)
Scangauge II
Elite Offroad hybrid sliders installed
Combined blinker/corner light mod
Wheeler's "Super Bump" bumpstops, rear
Military-spec battery terminals
Trail Gear low profile front bumper, light tabs, primed and painted
Lightforce 170 strikers, yellow combo lenses
Homelink module
33-tooth speedo gear swap (P/N: 33403-39415)
Autometer boost/vac gauge + a-pillar pod
LED license plate lights
Auto down/up windows (2x Autoloc WC1000)
Wet Okole seat covers (black & charcoal w/TRD Off Road logo)
Warn M8000-S, OTRATTW switches, wiring for in-cab controls, relocate solenoid box to engine bay
Frame reinforcement (CBI Fab frame plates $80, Total Chaos spindle gussets $35) - Installed by Performance Welding, Bothell, WA
Big 3 wiring upgrade
RAT 1/8" steel skidplate (TacomaWorld)
Seam Seal on frame reinforcement plates
HO alternator, 130 amps (TacomaWorld)
ARB snorkel (ARB SS170HF)
Autometer clock (P/N: 7585)
Grillcraft mesh grill
6-switch mounting plate (TacomaWorld)
OTRATTW switches
CBI CB antenna ditch mount
Custom neoprene winch cover
Sound Ordnance B-8PTD
Ignition ring light
G Tek Fab door sill protectors (TacomaWorld)
Tripp Lite PV375 power inverter
Steering wheel shaft tack-weld (original welds snapped)
Hella Supertone horns
OME trim packer - 5mm (driver's side)
All-in-one key (TacomaWorld - Neneago - http://www.tacomaworld.com/forum/1s...-key-one-single-unit-fcc-bab237131-056-a.html)
Red/clear tail lights
Rustoleum bedliner on sliders and rear bumper
Blue Sea 12v outlet in bed (changed RTT connection to Blue Sea 12v plug)
Bed rack mounts for Hi-lift jack & base
Garmin Nuvi 2557 LMT, with hardwired connection
Glove box lighting (6" LED bar from VLEDS.com)
110v/USB inverter outlet
Line-X bed (Truck Builders, LLC - Lynnwood, WA)
Air Lift ride control kit (#59537)
Redo bed rail lighting
Garmin BC30 (backup camera)
Amber LED footwell lighting (Two 6" aluminum bars from VLEDS.com)
LED auxiliary backup lights
Modular/split rear seat platform
VersaTie track (Mac's Custom Tie Downs)
Tie down anchors (Mac's Custom Tie Downs)
Headlight retrofit (TW - LSC15 - Mini D2s, 4500k 35w, Ocular shrouds, blacked out, new housings) + vleds aux turn signals
Remove ABS pump/lines // Install OEM front non-ABS lines, custom rear lines with Wilwood manual proportioning valve
Dual battery setup (Blue Sea ML-ACR, Exide Group 34 AGM deep cycle battery, wiring, terminals)
Windshield washer reservoir relocate
OME 882 coils
Color-matched grille, bumper fill plates and corner lights (AutomotiveTouchup.com Paint code: 3L5)
Rebuild projector headlights
OTRATTW switch plates (Contura XIV)
Canopy + Rebuild
Camping/sleeping platform
PrInSu Design Studio Cabrac + Canopyrac, stainless hardware
ARB 1250 awning, custom mounts, stainless hardware
ARB 2000 awning, custom mounts, stainless hardware
Covert un/lock switch
OME D43XL AAL + U-bolts + Daystar greasable front leaf spring hanger bushings
AVS In-channel vent visors
Rotopax "Fuelpax" 3.5 gal fuel can + mount
On-board water
Side (area) LED lights
Kenwood KMM-BT518HD digital media receiver
Pioneer TS-A6886R (x4) speakers
Pioneer TS-SW2502S4 10" subwoofer, Kenwood KAC-M3001 amplifier, Custom 3/4" MDF enclosure
Asking: $16,999
OME suspension
Camburg UCAs
Factor 55 link
Canopy
Prinsu roof racks
ARB awnings
Rotopax
Water pump
Too much to list!
Grey wire mod
Pioneer DEH-P9400BH
Deckplate mod
Debadge
Camburg UCAs
Scangauge II
Homelink module
OTRATTW switches
Ignition ring light
OME 882 coils
Canopy + Rebuild
On-board water
