Guest, UPDATE We went through the site migration runbook and completed all steps. We will need to complete the migration next week, but will leave the forums up for the weekend. A few days after maintenance, a major upgrade revision to the forum site will occur.
I purchased a 2011 Jeep Wrangler and was doing some fluid swapping and discovered. That I have a rear locker. It’s an electric locker that is not hooked up. Looking for help in the form of the best way to wire it up assuming it works.
Depends on which locker it is. The Eaton has a couple heavy duty relays inline, even if you are using something like an sPOD or other control center. What is required realy depends on which one you have. Unless you are completely comfortable with taking a diff apart take it to a reputable shop and have them check it out. I have an Eaton 4pinion wired to my sPOD.
