Is my Range Rover Sport suitable for road trips?
Los Angeles
Angel
Lee
My vehicle is a 2017Land Rover Range Rover Sport HSE DYNAMIC. no modifications or upgrades at all. I usually do light off-roading with friends on unpaved roads and occasionally wade in water. Are upgrades and modifications necessary if I plan long trips and road trips? What modifications are more practical?
PS: I plan on uploading pictures but can't post them. I'm not sure which format to choose for the pics either
Check your suspensions before you go on any long trips...air suspension (rubber boot) tends to fail.
Difficult to find parts on long trips.
So am I buying a couple to put on the car? Buying a full suspension to put in the trunk doesn't seem worth it.
It is something that you can change on the road. Convert to coilovers if need be. Spares will not help.-..it is a big job.
I camped/backpacked all over California and cross-country three times. The most common issues were tires and Marmots chewing tires.
Upgrades and tools/spares are entirely dependent on where you plan to go and your repair knowledge level. Least is you should be able to change a fuse and fix a flat.
I was with a group of Rovers in Death Valley one year and one of the Rangies broke a pipe on the suspension. No one had a means to repair it so it meant a long drive back to LA in limp mode. Just a couple of fittings might have saved his trip.
Ya never know!
This is crazy. Groundhogs actually chew on tires. I need to replace my tires with sturdier All-Terrain Tire then!
