Increase camper shell capacity for rooftop rack
Indianapolis, IN, USA
Price
Unfortunately I bought my truck with a ARE CX Classic camper shell, not the HD. I want to put a rooftop rack on it but need to increase the capacity. The only reinforcement system I can find is a Milford Loadmax. But they’re out of Australia and it’s expensive to ship. Any similar products out there?
zgfiredude
Steward I
3,953
Silt, CO, USA
Brian
Nichols
Firefighter
What about fabricating an external version to support the roof rack, and then the shell is removeable and uncut?
zgfiredude
Steward I
3,953
Silt, CO, USA
Brian
Nichols
Firefighter
There is also the Gobi rack that would be over the cab, but it's probably not the look you want either. Nice rig by the way!!
Price
Correct, not looking to go over the cab. And thanks! I just put sliders on it and removed the steps. I'm putting sway bar disconnects on next. The reason for my post is that I will have a Front Runner Slimline II roof rack, Roofnest Condor hard shell rooftop tent, and an Overland Vehicle Systems batwing awning showing up tomorrow. Put the cart in front of the horse, need to beef up that camper shell to hold it all.20264299-2176-44E8-9B8D-247A6F543B56.JPG
Price
i bought an ARE cx classic for my tundra and it works great for the small amount of weight i put up there. i'm sure you could fab something up, but i'd check the thickness of the hd versus the cx. the hd series has triple the weight capacity, so i would expect some thicker glass in areas.
the shells arent that expensive...i'd rather sell the cx and buy an hd that is built factory to take the extra weight. if mods arent done right, the glass will crack and spiderweb, especially if weighted down and going over bumps.
The HD actually has an internal aluminum skeleton frame to transfer the load to the bed rails. And they don’t sell it separately so I’m stuck with something 3rd party or self-fab unless I sell it. And they’re on back order for 20 weeks…
BlackDog1
The Mitt
C
I had ARE Z series on my F150. I wanted the same set up. I contacted ARE and asked about loads etc. They said the cap would def handle the rack and tent weights it depended on the load capacity of the tower/feet attached to the cap itself. I assume the rack will be mounted by t slot rails? Possible to make an internal support using t slot channel aluminum? Modular Framing Systems - TSLOTS
Reactions: johnlucasprice
Uberland
Springfield, VA, USA
Jason
Brown
OP: I’m happy to provide pics of the internal skeleton on the ARE HD cap that (hopefully) will end up on my truck in a few weeks. I ended up going that route because no topper makers would give me a firm weight limit…it was always a “you should be fine” or “about that much” with blank looks when I asked about static versus dynamic weights.
Reactions: Innkeeper 41
Price
I spoke with ARE and they said their internal skeleton was meant to go through the cap and mount a rack directly to it. That means the roof rails that are on my cap wouldn't work with their aluminum frame anyway. Their frame is meant to remove ALL load from the cap and put it into the frame.
Reactions: grubworm
AnthonyBroussard
Lafayette, Lafayette Parish, Louisiana, United States
Anthony
Broussard
cnbuch23
Rhinebeck, NY, USA
Cooper
Buch
OP: I have found myself in a similar predicament (have a cx classic and want to put a rtt on it). How'd you solve your problem ultimately?
ThundahBeagle
Massachusetts
Andrew
Beagle
OP has not been seen on these boards since the month he wrote these posts - the Ides of March over two years ago, sir
