5.4L V8
4WD
6.5 ft bed
107,3xx miles
Second owner (purchased in 2010)
Non-smoker owned
Built for chasing the Baja 1000 in 2016/17.
The list of upgrades and mods is extensive. I have kept a log of all the work done and every fuel-up with mileage.
Engine Bay:
[ ] NEW Dual Optima Yellow top Batteries (2)
[ ] NEW spark plugs
[ ] NEW belt, idlers, & tensioner
[ ] NEW rocker arms
[ ] NEW valve cover gaskets
[ ] NEW Banks shorty headers w/ heat wrap
[ ] NEW starter
[ ] Cold air intake
[ ] 270 amp alternator
[ ] LED lighting under hood
[ ] Train air horns
[ ] AmsOil full synthetic oil
[ ] Fumoto 1/4 turn oil drain plug
Drivetrain:
[ ] Eaton TruTrak limited slip differentials front and rear
[ ] 4:11 gears
[ ] Trans service at 106,845 miles. AmsOil
[ ] New front axles
[ ] New front brake pads
[ ] Stainless steel braided brake lines (all 3)
[ ] Black powder coated OEM wheels
[ ] BFG AT KO2 315/70 R17
Suspension:
[ ] ICON 2.5" remote reservoir coil overs (front) 150psi N charge
[ ] Camburg upper a-arms
[ ] ICON 2.5" remote reservoir (rear) 250psi N charge
[ ] Deaver rear springs (+2", +1000# load)
[ ] Air Rite rear air bags w/ Daystar cups
Exterior:
[ ] Hard Notched Customs front bumper
[ ] Smitty Built 12000# winch w/ synthetic line
[ ] Custom 1/4" aluminum skid plate
[ ] N-fab nerf bars w/ steps
[ ] Bushwacker fender flares
[ ] Towing mirrors (extending)
[ ] Chase rack with Vision X lighting (12)
[ ] Maxtrax
[ ] Shovel
[ ] Line-X bed liner
[ ] Tonneau cover (soft roll up)
[ ] LED Down lighting in bed
[ ] 38 Gallon transfer fuel tank w/ 8 gpm pump
[ ] Vivair Air compressor w/ 2.5 gallon tank
[ ] L-track tie down anchors in the bed
[ ] Power box installed for expansion. Has volt meter, USB & accessory plugs
[ ] Hi-Lift extreme jack with accessories.
[ ] Custom built rear bumper w/ swing out tire carrier and storage box. 3000# trailer axle bearing on hinge. Hidden hitch. Padeyes. Air chuck.
[ ] Adjustable hitch. 2" & 2 5/16" balls.
[ ] Backup camera.
[ ] Locking fuel cap
Interior:
[ ] SCT Livewire tuner
[ ] Heated Leather Seats
[ ] Gorilla floor mats
[ ] Dynamat in overhead of cab to reduce wind noise
[ ] Lorance Baja GPS
[ ] Kenwood VHF radio (w/ pendant speaker)
[ ] President CB w/ PA speaker
[ ] Radio w/ cd & XM satellite ready
[ ] Winch controls
[ ] Lighting controls in overhead panel
[ ] Air regulators for air bags
[ ] Electrical distribution system
[ ] Co-driver horn button
[ ] Pistol magnet on dash
[ ] Additional LED cabin lighting including floor
[ ] Rear seat has been removed and replaced with a custom 6 door aluminum storage box. LED lit by auto on/off switches.
[ ] Wired for an Inverter (the one I had installed just released the magic blue smoke)
[ ] Windshield sun shade
[ ] Fuel pump disable (anti-theft) switch.
Extra stuff included:
[ ] 4 keys & 3 key fobs
[ ] 2 full size spare tires mounted on stock aluminium wheels. (1 tire is brand new. 1 tire has been shaved to remove uneven wear)
[ ] 2 extra OEM aluminum wheels
[ ] 1 set of highway tire chains for the 315/70-R17 tires
[ ] Spare upper & lower radiator hoses
[ ] Heater core hose 4L3Z18472BB
[ ] OEM mirrors
[ ] OEM air intake
[ ] OEM shocks
[ ] OEM alternator
[ ] Spare OEM power steering hoses
[ ] Spare Thermostat
[ ] Spare bulbs
[ ] Spare serpentine belt
[ ] Rear bed hoop. Can be used for mounting RTT
[ ] 1 AmsOil oil filter
[ ] 2 gallons AmsOil 0W-20 oil
[ ] 3 gallons Motorcraft coolant
The bad:
-The truck is not rust free.
-The windshield has a circular crack from a rock strike. It hasn't changed or grown in three years.
-The front seal on the transmission leaks a little.
-The driver's side mirror is slightly damaged and the courtesy light in it doesn't work.
-There is some wear on the driver's seat and a little damage from when my cat got in the truck.
Add a roof top tent to complete this overland package and start your next adventure.
4WD
6.5 ft bed
107,3xx miles
Non-smoker owned
Engine Bay:
[ ] NEW spark plugs
[ ] NEW rocker arms
[ ] NEW starter
[ ] Cold air intake
[ ] Train air horns
Drivetrain:
[ ] 4:11 gears
[ ] New front axles
Suspension:
Exterior:
[ ] Maxtrax
[ ] Shovel
[ ] Backup camera.
Interior:
[ ] Winch controls
[ ] OEM mirrors
[ ] OEM air intake
[ ] OEM shocks
[ ] OEM alternator
[ ] Spare bulbs
The bad:
