Extruded aluminum build
Vangie
San Diego, San Diego County, California, United States
Vangie
Mamalakis
Hi, All!
I’m in the process of configuring my Bronco Sport Badlands for overlanding…. Since there are next-to-no aftermarket accessories for the vehicle, i’m trying to find someone in the San Diego area that can work with me on interior modifications …
Is anyone in the community aware of a company or individual i can contact to do an extruded aluminum build?
Many thanks for any resources or suggestions! ✌
danwyandt
Trail Mechanic III
6,159
Burnsville, NC, USA
Daniel
Wyandt
WRTJ513
Hi, All!
I may be mistaken, but I thought ARB was offering Bronco add-ons
Reactions: Vangie
Vangie
Vangie
Mamalakis
Hi, All!
IL mY be mistaken, but I thought ARB was offering Bronco add-ons
Thanks for responding! ARB add-ons are only for the Bronco—not Bronco Sport…. I’m unable to find molle panels for rear window area or any storage system that allows me to sleep in the Bronco Sport Badlands and have internal storage space…. That’s why I’m trying to find a way to install an extruded aluminum “skeleton “ inside the BSB for use with molle bags…. ✌
OB Executive Director
Hi, All!
Welcome to Overland Bound
You might ask this question on the regional page or one of the build pages.
Overland Rigs
Don't hesitate to contact your Regional Director @Narbob for help or information.
Some contacts for local information are @Barclay (LA) @FrankRoams (OC/SD) & www.Riggedfordirt.com @Dominic OB0158 (Inland Empire)
RESOURCE MAP
Adventure and Expedition Tutorials
Overland Bound Meetups
Overland Trip Planning
Reactions: Vangie and Boort
Vangie
Vangie
Mamalakis
Hi, All!
Overland Rigs
RESOURCE MAP
Kent, i am grateful for the wealth of information you provided! I’m just beginning to interface with this app/community and am on a learning curve…. The resources you provided will be central to finding the contacts and community-building i need….
With appreciation!✌
The San Diego meetup is on the map, they might be able to help you with your build question also.
reaver
Caldwell, ID, USA
Brian
McGahuey
GMRS WRMV941
Just so you're aware, 8020 can be cut with most standard woodworking tools. If you have a mitre saw and carbide tipped blade, it cuts just like wood.
Vangie
Vangie
Mamalakis
Thanks, Reaver! i was trying to find some assistance , though, because this won't be a basic carpentry-skill build (basic carpentry i can do)...: the configuration of the cargo accessory makes the build more complicated than i think i can successfully pull-off.... ✌☺
Vangie
Vangie
Mamalakis
Overland Rigs
RESOURCE MAP
Thank you for the resource chain! Will explore!
Tupenny
Longwood, Florida
Boulder
Dash
Powertec makes several shapes, sizes and colors in a few lengths options and just like reaver said, totally cuts clean with a miter saw or a hack saw. A touch of sandpaper on the cut ends and you're good to go
reaver
Caldwell, ID, USA
Brian
McGahuey
GMRS WRMV941
There's also a piece of software that works like CAD for 8020. I will allow you to design and preview the entire build, and know exactly how long each piece is going to be prior to ordering.
Then, you can even order it pre-cut, then it's just a matter of sliding the t nuts in, and tightening the screws.
When I was planning my storage system, I was originally going to go with 8020, but when I looked at the cost of everything needed, went with wood, as it was MUCH cheaper to build. But, that's me.
You can totally do this!
Reactions: Vangie
roots66
Local Expert, Texas USA
Weir, TX, USA
Roots
GMRS: WSGB862
USAF
Hi, All!
Vangie
Vangie
Mamalakis
Thanks so much for the link and the encouragement, Reaver!!! Little bites at a time, i’m researching a combination of a plywood hatch and 8020 molle frame for vertical wall use…. Really appreciate!
reaver
Caldwell, ID, USA
Brian
McGahuey
GMRS WRMV941
No problem! When I was designing my trailer, wood prices were super high, and was going to be cheaper to build the frame for the box out of 8020. When it came time to actually order materials, prices had changed, and wood was much cheaper, so I went that route.
Reactions: Vangie
