DIY Portable welder/ Self powered welder. Updated 2/11
Ontario California
SMR
KO6BI
This has been on my project board for a number of years. In the past I ran with a home made alternator welder and always wanted to set it up with a spool gun. Having an on board welder came in quite handy multiple times. As it turned out, most vehicles we ran off road really couldn't take it. Time went on, parts and vehicles got better and I saw myself field welding fewer vehicles. As it is, my current vehicle is the only one out of my last four that doesn't have a welder. This weekend I decided to change that.
Because I'm cheap and like to do things myself, I chose not to buy one of the already made on board welders. I also didn't want to buy an expensive spool gun to convert if it wasn't going to work like I thought.
Because your welding with innershield wire, it needs 24volts. You need to series two batteries and isolate them from your vehicle. The spoolgun motor is 12volt. This will be hooked to only one of the batteries.
Like all my projects, their a work in progress. It normally takes me several tries before I either scrap it or perfect it. This one looks like it needs two things to make it right.
1. me to be a better welder.
2. a wire speed control. UPDATED 1/23 Speed controller pictures at the bottom
Here's some pic's with a few words.
Cheap Amazon spool gun.
The way these are set up, the trigger is wired to the welder and the welder turns on the spool gun motor. Here I have exposed the switch and motor.
Now to connect the switch to the motor. When I pull the trigger, the spool motor will run.
The other end of the cable had two plugs. One large one for the main power and a small one for the control. I cut off the large one and installed a single lug. The control plug was replaced by a pair of wires with small alligator clips. The spoolgun needs to have the wire feed be Negative and the metal be positive because your using flux wire. The main power lug will go to the negative post of one battery.
Power lug hooked to one battery, negative and the motor control hooked to both positive and negative on this battery. My red lead ran off the edge of the picture here so you cant really see it.
This is my other battery. I used my jumper cables to tie the negative of this battery to the positive of the other. I'm using my other jumper cable to bring positive voltage to my metal (remember, spool gun must be negative).
Front view (kinda hard to see everything).
Please don't make fun of my welds. These were quick tacks because it started to drizzle on me. The upright and lower plates are 1/4 inch and the square was 1/8 inch. I overheated the 1/8 inch and had to come back over it. The quarter got good penetration. I was using very old .035 wire.
Finished (sort of) Spool gun.
Final comments. I was using some wire I had laying around for....10 years? The size was .035. I want to try .023 wire. It will flow less current and most likely will work better. I also want to add a small speed control to the motor. Dont know if it will help or not.
Overall if I needed it right now as it sits it would work very well, especially if I practiced some first. I need to figure out a small portable helmet and maybe a hard case.
With the hard case and possibly the helmet, I should still be under $200. $125 of that was the spool gun itself. Used one on eBay would save a bit.
UPDATE: I added the speed control. It works well without it but is actually better with it. As far as I can tell, none of the store bought types have a speed control. To me, the wire speed at 12 volts is too fast. I found dropping the voltage to about 10 volts works very well with the .030 wire.
Here's some pictures
Speed controller
Amazon special. I wanted something smaller I could incorporate into the gun. The only way to make that happen was to build my own. Way easier just to buy it. The only bad thing about the one I chose was, it didnt come with wiring instructions. I had to go to the Amazon picture. Details for the one in the picture below is backwards. I started to let the smoke out when I hooked it up. Fortunately the controller is still good.
I did not get any pictures of the board wiring before I sealed it (sorry). Its basically hooked up inline . I didnt need to see the display because the speed I want is just back a little from max.
What I have left is, find a nice box for it and get a folding/compact welding hood.
Finished project with controller
geekyadam
Mead, CO, USA
Adam
Wright
2. a wire speed control. (ordering the parts as we speak)
Love it, perfect for emergency trail use. Nice work!
geekyadam
Mead, CO, USA
Adam
Wright
Reactions: smritte
El-Dracho
Ambassador, Europe
Supporter
Protector III
14,131
Lampertheim, Germany
Bjoern
Eldracher
DO3BE
That seems to be perfect for trail repairs. Great DIY-project. Thanks for sharing!
Reactions: Bad Sport
KonzaLander
Traveler II
3,402
Junction City, Kansas, USA
KE0EBF
Great write up! I am definitely going to build this.
How much energy do the batteries loose while welding? I guess the better question would be, how long could you weld and retain enough power to start the vehicle with your group 34 Odyssey batteries?
Ontario California
SMR
KO6BI
Its funny you ask that. I was thinking about it on the way to work today. I'll bet I could burn through quite a bit of wire before I had to worry about battery charge.
What made me think on that was looking at the Karnage welder. They put it in a case with some lithium batteries. They claim 20 mins of welding time before charging. With all the field welding I've done, I don't think I spent more than 10 mins of actual weld time.
Looking at the karnage pictures, they cant be running a very big battery. My thought is a couple of 12 volt lithium's in a pelican case. I was going with two 12 volt because its easier to charge and I could rig it to also be used as a jump starter if needed.
I may mod this to be self contained.
Ontario California
SMR
KO6BI
New update.
I finally finished the portable battery part. I'm just going to post pictures and not a whole part break down. If anyone wants to build one, message me and I'll get you a part list. You could also use the info to build your own battery bank for camping.
As it turns out, most of the major welding companies had a battery powered welder, a few years ago. They were very expensive and only good for small things. They designed them around their professional machines. Basically, they took one of their welders, added in a battery and inverter. This added weight, added higher cost and drew down the batteries quickly. The people complained because they thought they were buying a welder they could use all day.
Another group builds the Karnage welder. A friend of a friend, did a pod cast with them and they mentioned lithium battery's was something they couldn't get correct. They achieved the voltage using two small 12v AGM's (24 v).
From what I researched, no one seemed to figure out how to achieve high current without resorting to AGM's.
MY build uses Headway 38120 batteries. each is rated at 200 amp's. I use 16. Two groups of eight. The output voltage is 24v (High) and 18v (low). I welded 1/4" to 3/8. The weld was good but that's the limit of a single pass. If I wanted thicker, I would increase the wire size.
18v Is a bit light on 1/4 but rock's 3/16 and 1/8.
Testing the battery pack, I'm getting about 140 amps on high and 110amp's on low. I spent about 20 min's playing with diffrent metal thickness and depending on a few factors it should last 20-30 mins of solid welding. The batteries stayed cool the whole time. That was one of my worries.
I decided having a dedicated 18-24 volt battery was useless as a general battery supply so I added two 12v Anderson plugs. I have a 24v-12v converter. Charging the pack is done with a 12v-24v converter. Everything I've done is set up around Anderson connectors. One issue popped up while I was testing. The spool gun would stop working after about 10 seconds of usage. Whet it turned out to be was the welder was creating voltage spikes. This made the 24v-12v converter angry. Considering the spool gun wants 12v, I tapped power straight from one of the 12v banks. Problem solved. Looking back, I could pull 12v from each bank separately and wire those to my 12v output. The Anderson plug has two outputs. This would work well except the capacity would be in two part's. It would on the other hand eliminate the 24v-12v converter.
The only part I will change in the whole system is my spool gun speed controller. I finally found one that fits in the gun itself. I was going to make it part of the battery pack until I realized I wouldn't have speed control if I just used my vehicle batteries. I will say this. The speed control make this whole thing work very well.
Picture time.
Ssidener
El Dorado Hills, CA, USA
Shawn
Sidener
Evening. Great write up.
You mentioned you installed a new smaller controller in the gun itself. Would you mind posting that part number and possibly some photos?
Ontario California
SMR
KO6BI
I tried a couple diffrent controllers, nothing fit. I would have to have one made. I went to a 10 ohm potentiometer (20 watt?) as a speed control in the main box (for testing). So far it works great. I will probably put that in the gun.
I was going to do a final write up on it once I move it. I've added a few more features also.
Reactions: KonzaLander
