Hi, Well I've been putting it off but my business has determined I need to sell my 2015 Jeep Wranlger JKU conversion. I'd like to just post a list of the modifications but there is so many you'd never read through it all but, I will give it a shot. I'm looking for as little drama sale as possible which mean I'm ready to be extra generous in what's included. The truck has taken a few different forms. It was at the SEMA show three years running. The photos below are how the truck sits right now.
So... what's included...
2015 Jeep Wrangler JKU Sport S with just over 30,000 miles
MVS (Michigan Vehicle Solutions) 4 door truck conversion with drop down tailgate
DV8 Heat reduction hood - stamped steel - I have the original RK Sport fiberglass ram air intake hood too
Rugged Ridge hydraulic hood lift kit
Angry Grille - not sure on brand on this one... I thought it just look cool
Entire vehicle including the inside top was coated in Line-X Ultra material color matched to Jeep Rhino Grey
Kentrol stainless steel mechanical hood latches - painted texture black
Kentrol stainless steel hood hinges - painted texture black
Kentrol stainless steel windshield wiper arms - painted texture black (with new Rainx wipers)
Kentrol stainless steel door hinges - painted texture black
Kentrol stainless steel inner door kick plates - painted texture black
Rugged Ridge cast aluminum locking fuel door - keyed - texture black
Spyder Auto LED head light kit
Spyder Auto LED tail light kit
Suparee front LED turn signals - smoke lens
Go Rhino Dominator D6 Running boards with removable drop steps x 4 - texture black
Go Rhino Trail Line stubby front bumper with locking trail drawer & light bar mount - texture black
*Front bumper has 2 Rigid XL's, 2 Rigid standard dually's on top of light bar and a Rigid Capture light that houses a Go Pro already wired to the cab. A Warn Zeon 12 with steel cable & wireless remote all powered and working corectly, roller fairlead with Warn Epic Hook. I also have some Factor55 D ring mount and hawse fairleads that may be included. 2 Warn Epic D Rings
Go Rhino Road Line 3" frotn and rear steel fenders - also called fender delete kit - texture black
Go Rhino Inner Fender Liner front and rear kit - texture black
Go Rhino Windshield Light Frame - changed since photo - includes one Rigid 40" double row E series LED bar, 2 Rigid Dually's on top, 2 Rigid Dually's lower on the A pillar & 2 Rigid Dually side shooter lights mounted at he bottom of the A pilar.
Go Rhino Trail Line Rear Bumper - texture black - with 2 Rigid SRQ series LED's & 2 Warn Epic D Rings
The pigtail on the roof is a disconnect for a rood rack that was taken off. The rack could be replaced.
Black Rhino Madness wheels x 5
Gorilla spline lock lug nuts - semi-gloss black with key
Currently has Mickey Thompson MTZ 37 x 12 x 12.50 Tires x 5 with unused spare
Fabtech 5.5" Crawler suspension lift kit with front Dirt Logic 2.5" coilovers - all stainless steel
Fabtech hydrualic front bump stop kit installed - stainless steel
Fabtech hydrualic rear bump stop kit NOT installed - stainless steel
Off Road Only (ORO) Swaylock mechanical sway bar disconnect - quick lever -
Factory front & rear axles rebuilt with Synergy Manufacturing axle sleeve assurance kits & a complete rebuild with Yukon chromemoly axles, 5:15 gear sets & Yukon front and rear air lockers
Synergy Manufacturing HB Ball Joint set 2 upper & 2 lower
Reid Racing knuckles
Steer Smarts Yeti XD top mount draglink with Griffin XD
Steer Smarts Yeti XD JK Tie Rod Assembly
Steer Smarts Yeti XD Damper Bracket
Power Stop Z23 Brake and big rotor kit
Outlaw cast front & rear diff covers - Jeep branded
Viair dual air compressor system with on board 10 gallon tank mounted under the bed all wired to cab for air and lockers
Mechman 200 amp alternator
Genesis Off Road JK Dual Battery Kit
Genesis Off Road G Screen monitoring system installed and wired to cab with 3D printed custom bezel
Painless Performance Products JK Trail Rocker accessory control system x3 - YES there are 3 - one under the hood and one each side of the truck under the bed mounted to frame rails
Odyssey Battery Extreme Battery x 2
K&N - AEM - Cold air intake system
Borla custom exhaust - stainless steel
Mishimoto Jeep Wrangler JK Performance Aluminum Radiator
Mishimoto Jeep Wrangler JK Silicone Hose Kit - red
Mishimoto carbon fiber 1.3 bar radiator cap
Mishimoto Jeep Wrangler JK Race-Line High Flow Fan , 16" - not installed
Mishimoto Jeep Wrangler JK 3.6L Racing Thermostat
Mishimoto billet aluminum coolant overflow tank - red
Mishimoto Compact Baffled Oil Catch Can 2 port - not installed
Mishimoto Heavy-Duty Trans Cooler with Fan - installed but not wired
Mishimoto billet power steering fluid overflow tank - red - not installed
Alea Leather seat black with red inserts - custom design
Bestop Under Seat Lock Box with keys for both driver & passenger seats
Quiet Ride Cab Sound Proofing Kit
2 sets of Rigid LED rock light kits - white light only installed and wired
Now a couple unfinished areas...
I have 10 to 12 custom Auto meter Jeep branded gauges. One was installed in a custom A pilar pod. The rest have not been installed and are still in the boxes.
The stereo is another situation. I removed the factory head unit (I still have it)
I had a terribly expensive Rockford Fosgate sound system installed. It cost $3500 to wire and the parts alone are / were about $15,000. I was trying to power the whole system by Windows tablet. I have all the control boxes and everything was wired up and working. I never made a customer bezel to hold the tablet. I never had the sound system setup or tuned. The sound system computer or controller from Rockford requires a professional to setup or maybe a NASA team! Now it's all wired but I can remove it all as well. It has new dash speakers installed with tweters, six inch speakers in the sound bar, 2- 10 inch subs, 4 amps, a controller and even a set of large outdoor speaker cans... like the ones you see on ski boats. It was all installed and wired and then I decided to change the roll bar so I removed it all and that's where it stayed for now.
There are other things there as well like handles and small things like that. I have tools, tanks, and off road gear that could be included as well.
Give me a call if you want to see it. I have a lot of build photos and photos from different shows it was at. It also starred in it's own commercial!
I'm looking to get $60,000 but for this week only I'll take $45,000. The parts list alone without installation is just over $120k. I also am selling a custom overland trailer that's titled and ready to go. The trailer has the same matching wheels! Looking for $15,000 for the trailer. It has the largest CVT RTT available, two awinings with annex rooms and even a upstairs balcany!
Thanks,
Tim 714-403-8776
Thanks,
Tim 714-403-8776
