Building a Tahoe Z71 for Adventure? Check Out This Hidden Light Bar
Burbank, CA, USA
Levinson
As more people are turning the 2025+ Chevrolet Tahoe Z71 into capable adventure and overland rigs, one upgrade that can make a big difference is adding quality auxiliary lighting without compromising the factory look.
M&R Automotive's 40" PRO Light Bar Kit was designed specifically for the 2025+ Tahoe Z71 and mounts neatly behind the grille using vehicle-specific brackets. The result is a clean, OEM-style installation that doesn't require cutting or drilling, making it a great option for owners who want additional visibility while keeping the front end looking stock. The kit also fits the 2025+ Chevrolet Suburban Z71.
Features​
  • Vehicle-specific design for the 2025+ Tahoe Z71
  • Also fits the 2025+ Suburban Z71
  • Hidden 40" PRO LED Light Bar mounted behind the grille
  • Bolt-on installation using factory mounting points
  • No cutting or drilling required
  • Available in White, Amber, or White with Amber DRL
  • Advanced TIR optics for improved distance and wide trail illumination
  • Built to handle harsh weather and off-road conditions
  • Lifetime warranty
If you're curious how it performs once the sun goes down, we also put together a nighttime light output video. It gives a good look at the beam pattern and the additional visibility the 40" PRO provides on dark trails, forest roads, and remote backcountry routes.
I'm curious how many people here are building out the new Tahoe Z71 for overlanding. What lighting setup are you running—hidden light bar, ditch lights, or a combination of both? It would be great to see how everyone is outfitting these SUVs for adventure.
Just wanted to bump this thread with another helpful resource for anyone considering the 2025+ Chevrolet Tahoe Z71 40" PRO Light Bar.
If you'd like to see exactly what's involved with the installation, we put together a complete walkthrough that covers the process from start to finish. Mike walks through grille removal, bracket installation, wiring, and final fitment so you can see how the kit comes together. It's a true bolt-on installation with no cutting or drilling required, and the light bar is designed not to interfere with the active grille shutters.
If you have any questions about the install, wiring, or choosing between the white, amber, or white with amber DRL options, feel free to ask. We're always happy to help!
