Better bought than built
jeepinjeepin
Wallburg, NC, USA
Josh
Webb
NC4WD, WRTJ904
What is that one piece of gear that you have that the name brand/original product is worth buying over the copycat or diy?
Reactions: Kozysnack
MOAK
Donald
Diehl
WRPN 506
I’ve several, seriously, several. But off the top of my head? Our ARB 64qt fridge freezer and our Engle 15 qt fridge freezer. The Engle is used as a freezer and is coming up on 11 years old. The ARB is right behind that at 7 years. Both operate flawlessly and use very little power.
Akicita
Firestone, CO, USA
Akicita
Lakota
- AluCab Shadow Awning -
In all my years living, working, and playing in the outdoors, I have rigged countless makeshift awnings and shelters. . . It's pricy but worth every penny for ease of deployment and sturdiness in heavy weather.
Mason County, Washington, United States
Haven Ridge
Adventures
Navy Retired
A good quality winch. This is an item that has to work when you need it.
On the other hand Bunker Ind. Traction boards are really great and cost about $70 a set on Amazon. I can't justify paying the Maxx Trax prices.
grubworm
louisiana
grub
worm
USN-Submarines
this is a great question to ask...
i use a lot of knock-off items because most of the time it really doesnt matter. like buying the great value walmart brand corn chips opposed to frito lay corn chips...whats the worst than can happen?
i dont take that approach with electronics or safety/recovery gear. although most things are made in china, there is still better quality control with name brand items (usually).
take a solar controller, for example... i use renogy and they are made in china...however, there is quality control because the solder joints are much better than they are on the cheaper knock-off versions. also, a lot of the wiring is better. a lot of the cheaper knock-off electrical tools are notorious for using cheap wire and poor insulation on motor windings, so that dewalt knock off drill that was $70 cheaper will probably fail rather quickly and definitely will not hold up to any constant use. same thing for cheap winches...their motor windings will probably use a copper clad aluminium wire with poor insulation that will not hold up for very long, especially in a rough environment.
name brand is also better concerning safety/recovery gear. one great example is a shackle. i did a lot of rigging offshore and we always used the Crosby brand shackles. purchasing got the bright idea to cut cost by buying shackles with CHINA stamped on them. we started having failures offshore and the cheap knock-off shackles were failing way before reaching their stamped SWL. after a few mishaps, any shackle stamped CHINA was banned from offshore use.
i do have some harbor freight shackles, but i dont use them for anything important
Ontario California
SMR
KO6BI
That reminds me of something I have heard people say when its suggested they don't buy cheap important gear. "I've never had a problem!". Then when it fails they say "I've never seen that before!" and act surprised. One of the guys at work will only buy cheap tools and gear. His stuff fails all the time and he accepts that. He would rather spend $500 over time then spend $200 initially and not ever deal with it again.
Then there's the people who convince others to buy cheap gear. They tell everyone "OMG, this is the greatest ever and it works flawlessly". Then they're offended when I ask, "how many other brands have you compared this to and how many years has it "worked flawlessly?".
People buying "cheap" important items doesn't bother me until it effects me.
Reactions: OTH Overland
ThundahBeagle
Massachusetts
Andrew
Beagle
-Leatherman.
-Victorinox Swiss Army Knife.
-Any of my old Craftsman tools. OLD ones, mind you.
-Buck Knife model 110.
-Ray-Ban polarized perscription sunglasses
-Trac Rac rack for the cap of my truck
JimBill
San Benito County, CA, USA
James
Madison
Coming from within the defense industry, the funniest one to me is when people tout "Mil-Spec" as the end-all be-all to a component or device credentials.
The spec in question can be for something that has to survive the bitter cold or heat of space, the severe vibrations of a rocket ride, a dip down to the titanic and back, or the like. OR it may define the cheapest viable representation of functionality- and the DOD will not pay a cent more for anything they do not need it to do. Think toilet paper.
Mil-Spec = Suitable minimum specification for the intended use, as defined by the agency that wrote the spec. So "Mil-Spec" may or may not be worth bragging about.
MidOH
Mid Ohio
Clark
YourHighness
I make all kinds of excellent alcohol stoves, but this kit is as impressive as my best stuff. And it also has an optional wood burner so I don't waste fuel.
Ultralight:
