SOLD ARB Differential Breather Kit (Model# 170112) - $40
HIALT2D
Prescott, AZ, USA
Glen
Stanley
WA6AAB
For sale in Orange County, CA
Brand New / Never Used. In original manufacturer's box.
ABOUT ARB 170112: The ARB Differential Breather Kit is designed to provide a high-flow, zero back pressure, zero vacuum breather system to keep your drivetrain free of water. This is achieved with a central high-flow air filter and manifold that will allow up to four drivetrain assemblies to be vented to one central location, positioned high enough to avoid water during crossings.
HOW DOES DIFFERENTIAL BREATHER KIT WORKS: It uses a central high-flow air filter and manifold that will allow up to four drivetrain assemblies to be vented to one central location, positioned high enough to avoid water during crossings.
PREVENT WATER FROM CONTAMINATING COMPONENTS: The ARB Differential Axle Breather Kit eliminates water from contaminating the oil and damaging your drivetrain components by providing a high flow, with no back pressure, zero vacuum breather system.
ARB 170112 KIT INCLUDES: Differential Axle Breather / Incl. Manifold / 4 Ports to Connect Up To 4 Breather Lines 7 Air Filter Port / Air Filter Assembly / Push-In Fittings / Plugs / Tubing / Screws / Cable Ties
Local pick-up preferred.
