FOR SALE Adventure Trailer for sale
OB Executive Director
2018 Anchor Mountain Overland (AMO) Enduro Adventure Trailer
$13,500 (No lienholder, currently PTI registered in CA)
Expedition-ready, all-weather, proven trailer, with large roof-top tent (with annex room) and tons of storage to fit all your stuff. This trailer is built to withstand the toughest off-road conditions and provide in-camp comfort and convenience.
Chassis: (All steel)
3x2” box steel main chassis, 2x2” backbone, 2x1” cross bracing for box; 2” rear receiver, 2” front receiver fitted for Max Coupler (included).
12ga steel fenders (walk on) with flat tops for more table/cooking area. Fender braces, rub rails and bumper can all be walked on.
Timbren Axle-less suspension, 3500lb HD. New 2020 Falken Wildpeak M/T LT 285/70 R17 tires (3) with Toyota 4Runner rims. 6x5-5 bolt pattern.
Body: (All aluminum)
6.5’ long x 4’ wide x 3’ tall; ⅛” thick aluminum box with large rear door and 30” wide side galley door. Both doors are ⅛” aluminum with gas strut assist and lockable paddle latches.
Rear Compartment:
A 42”x34” steel storage drawer with Front Runner Wolf pack totes (4).
Above is open with an ARB fridge slide installed. Includes Dometic CFX 3-35 Refrigerator/freezer (new in box). Baja Designs dome light inside.
Side Compartment:
Power center with sPod 6-switch system; Norco battery monitor with power point; dual USB charging points and voltage monitor by Blue Sea; Diehard AGM battery with Norco charger/maintainer, 100 watt portable solar panel. Front Runner 14.5gal stainless steel water tank and pump. 26x36” pull-out aluminum galley with sink, counter space, and drawer. Baja Design Dome light inside; storage shelf with Front Runner Cub storage boxes (2) included.
Exterior:
Front and rear LED work lights, side kitchen LED work lights, rear chase light bar (for dusty conditions) is actuated from tow vehicle through the 7-prong trailer plug. Camp Chef Triton 5L on-demand water heater is mounted on the exterior in a Pelican case, perfect for hot shower or doing dishes. 11lb propane tank with mount included. Front 5k tongue jack and two rear 5k jacks for leveling and changing tires. 20L Wavian fuel container with mount. Full-length HD Aluminum tent rack. ARB Touring Awning, 1250mm x 2100mm. Tent is 4-season canvas. See more specs at link listed below.
Rooftop Tent:
HiTent rooftop tent - 72” x 96” sleeping area (larger than Cal King); sleeping area covered by anti-condensation mat; sleeping pad/mattress not included. Includes rain fly. When closed, the folded tent is covered with heavy duty vinyl cover.
HiTent Annex Room - Zip-on canvas annex/room with vinyl floor; floor space is approx. 7.5’ x 8’. When the annex is attached, you can exit the tent directly into the annex for complete privacy and weather protection. Annex is stored in a bag inside the trailer.
Overall the trailer is 11’ hitch to bumper and weighs 2200lbs loaded. The box is powder coated Dove Gray. The chassis is powder coated black. Trailer shows some wear and tear from regular use, but is in top operating condition.
Links:
Tent/Annex
Expedition Grade Huasna — Hinterland Industries Tents
Timbren Axles
Timbren ASR35HDS05 - 3500 lb HD Axle-Less Trailer Suspension with 4-inch Lift
6000 lb. Electric Brake Hubs - 6x5.5 Bolt Pattern
Refrigerator, Dometic DFX3-35 (new in box)
Dometic CFX3 35 - Powered Cooler, 36 l
Front Runner Wolf Pack storage boxes
Wolf Pack - by Front Runner
Cub Pack - by Front Runner
I have three 35x12.5x17 BFG KM3's for it but they are on 5/5 jeep rims. The tires on it are from a Gladiator with Toyota rims
Yes it is, we just started to show it again after the holidays
Reactions: KAIONE
FirenzeForza4x4
Napa Valley, CA, USA
Apal
KN6SNX
Hey Kent, trying to do some research on AMO. Are they shut down now? Also do you know whether Hitent sells replacement mattresses?
Cheers,
To my knowledge AMO is no longer in business, his wife told him they were moving to Florida.HiTent does sell mattresses but you can get better foam from foam dealer. All the tent mattress suck
If you do get foam, I would advise not getting memory foam because it freezes
My wife loves the tent anex, fully inclosed for getting dressed or using if for a bathroom. Shower you still need a portable shower tent.
Reactions: Yanomami
Reduced price
Reactions: KAIONE
