A helping hand, a borrowed tool......a driveway
Would you do your own work if you had the tools or a place to do them?
  • No. I don't trust my skills
    Votes: 0 0.0%
  • NO! It's all black magic and has to be done is a shop
    Votes: 0 0.0%
  • Total voters
    10
Snowwalker
London, Ontario, Canada
Doncaster
VE3NLP
OK Now I know that not everyone is lucky enough to have a fully equipped shop and all the tools, to do repairs, mods, or even maintenance. Some people would just like a helping hand to get a project or install done,. Maybe it's just moral support to easy the nerves.
So lets start a list and thread of people that need help in the Southwest Ontario area to do things.
Anything you need, just shout out. Live in an apartment and simple need a place to simple change oil, or need help and tools to change a ball joint it does not matter.
I'm in London, I got a driveway, some tools, experience and no one on the street is going to call the by-law on me/us.
My up coming projects are upper arms replacement on my tacoma and a complete lift install on the wife's new 4runnerl. What to meet and help, or just see how it's done, drop me a note.
Need a spot or a hand to working on something post up, and let see if the local members can help each other out..
Billiebob
earth
Bill
Yes, I do tons of work in the driveway.
No, I won't touch welding or steering, there are guys with journeyman tickets who are far better skilled than I will ever be. AND I've found they are a bargain, way cheaper than buying all the supplies, tools, safety stuff and hoping I guess correctly.
Can I change oil, sure but if I let the shop change the oil they also check the driveline, steering, lighting, brakes.... for under $100. so why change the oil at home.
If I have a project in the design stage. I finish the design, do a bunch of preliminary work, then farm out the stuff which is best done by a journeyman. If you plan it well, you will save money hiring out the specialized portions.
Other things like gas fitting a propane stove, instant hot water etc, I do all the preliminary work but hire a guy to do the final gas connections, sometimes he will spot errors like where the exhaust is related to a window or door. That guy with a journeymans ticket can save yer life.
Good to hear you are willing to share, watch out for liability, you are inviting folks who might have ulterior motives.
dhossk
Atherley, Ontario, Canada
Dalton
Hoskins
I do all my own installs myself as well..(minus mounting tires to wheels and alignments) I've been turning wrenches since I got my license, a Certified Driveway Mechanic I like to call myself lol.
I usually have a garage to do most of my builds/installs but it's currently occupied by a 77' F100 that has taken my interest!
Like Billibob mentioned above for Liability purposes, I only work on my own personal and families vehicles.. A friend of a friend is too risky without proper licensing and insurance.
That being said, I do like the idea! I'm sure there are others that would be more then willing to lend the shop space/tools. I know there is a shop around Barrie that let's you use their tools and hoist you just need to pay for the time. Not sure if the pandemic has an affect on that right now though.
Snowwalker
Doncaster
VE3NLP
Liability?? Sounds like a good reason to not do stuff. :disappointed:
You should not be doing stupid stuff, or billing your self as a Master Mechanic without a ticket, but helping a buddy or someone new to the hobby with some basics maintenance is a good way to make friends and grow the hobby.
How many problems, time and money could a guy save if someone showed him how to use a torque wrench, and to check wheel lugs or nuts and bolts before, during( daily pretrip) and after an overland trip?
You don't need 20 to 50 thousand dollars in tools, but you should have a decent setup. A 290 piece socket set, small Impact socket set and Impact gun, with a good selection of Wrenches. Total of two tool boxes, a socket case and an Impact gun, you can adjust, replace or install 80 to 90% of the parts on the vehicle. Need to do ball joints/Delta joints/Uni-balls, and tie-rods? A front end service kit only runs about $100 CDN, and makes changing a bent tie-rod on the trails way easier. Yes after I replace parts on the front end, I'll take it into the shop for an Aliment, cause I don't need a 15 to 30 thousand dollar machine that only gets use once or twice a year.
Billiebob says "Can I change oil, sure but if I let the shop change the oil they also check the driveline, steering, lighting, brakes.... for under $100. so why change the oil at home."
As for just letting the shop change oil, so they can tell me if my light are not working, or my brakes steering or driveline is "OK", Maybe you need to get your face out of the phone and check things like your lights about once a week yourself. Does your steering wheel feel funny, are your brakes not working as well as you like? Does your Steering shaft or driveline have too much lash( play) ? You should know if something needs to be looked at before the shop tells you. Well I may sound harsh about it, you as the driver are 100% responsible for insuring that the vehicle is safe to drive on public roads. Get pulled over on the way to have the oil changed so they can tell you that a light does not work will still cost you a ticket.
As for Oil changes only costing a $100+ for the shop to do, yup sounds right. Thing is my oil is going to cost me about $80, plus $40 for a filter. So why give the shop $100 to 150 on top of the cost of parts? I can drive to the store, come home let wife put stuff in the fridge and I drain the oil. Well I am under the truck, I can give my drivelines a twist and check the lash, check the torque on nuts and bolts etc. A nice relaxing couple hours working on the truck and talking to my neighbors. The money I DID NOT give to a shop is enough to pay for my next OIL change, or a tank of gas for a trip.
I should touch on the Liability thing in a more serious note. If I have to worry about Liability, there is a pretty good chance you are going to stay stuck, no recovery attempts because of liability. Need a ride? sorry Liability. Your Air compressor broke and you want to borrow mine to air up for the Highway. Sorry Liability.......Yes it sounds stupid, but 'Liability" is a real catch 22.
Think of it this way. I come across you stuck on a logging road or a trail. I can't attempt a recovery because of Liability, I can't give you a ride to town because of Liability, I also CAN NOT leave you stranded because of LIABILITY. How much Liability do I have to except and How much PERSONAL RESPONSIBILITY are you going to take if your vehicle or gear gets damaged in a recovery, or you spill a hot coffee on yourself well your riding in my truck?
scanny
Ontario
I can't imagine that any overlander or offroader would sue anybody who help them with vehicle repair or recovery. At least when people helped me and when I helped people, that just never occurred to me. Of course you're getting sort of consent for helping and inform other person that something might go wrong : ) I think that personal responsibility is not a foreign concept for people who does overlanding.
Trail_pilot
James
Girard
I am in Owen Sound, I can wrench and have a decent amount of tools and a welder, but I am in temporary housing and the electrical wont support the welder so I am SOL there. I am not a professional welder ( working on getting my ticket still).
I agree that liability is an issue, one of my friends had someone try to sue them after a recovery because something was damaged either during the stuck or during the recovery and they blamed him. it sucks but unfortunately its the world we live in these days. I still try to help out anyone I can but I am very cautious.
Reactions: dhossk
