I see the question pop up on forums every now and then.
I have my Ham Radio License now......now what?
or
I bought this radio. Do I need a license to use it?
or
I bought these little FRS/GMRS radios and I'm on the same channel as my buddies but they can't hear me!
Lets start with the Family Radio System / General Mobile Radio Service aka FRS/GMRS radios.
On to the next medium, Civilian Band Radio (A.M. version only)
Amateur Radio Service aka Ham Radio
Cons
or
or
- Both types are available through common chain stores.
- Both types are of channelized frequency selection (HEY, WE'LL BE ON CHANNEL 7).
- Both types have a secondary privacy channel ability, in order for the user to only hear traffic on their selected channel from users who are also using the same secondary privacy channel (HEY, WE'LL BE ON CHANNEL 7 and PRIVACY CHANNEL 3).
- FRS/GMRS operate in the FM mode, which offers the best audio quality.
- FRS operates in the UHF (Ultra High Frequency) range at no more than 500 milliwatts.
- GMRS operates in the UHF range at no more than 50 watts. Generally you will find hand held units limited to 5 watts due to FCC radio frequency exposure limits.
- Dedicated FRS and GMRS units have some channel overlap.
- Hybrid FRS/GMRS units will transmit on all FRS and GMRS channels.
- FRS does not require the use of an FCC license.
- GMRS requires the use of an FCC (no test) license. Sidenote: I have yet to meet someone with this license or hear of the FCC enforcing GMRS licensing requirements. I'm not condoning the unlicensed use, just an FYI.
- Most all FRS/GMRS handhelds use common disposable batteries and/or rechargeable battery packs.
- Mobile/Desktop sized GMRS units are slowly entering the market. These units can operate at a higher power setting due to the antenna not being mounted on the unit and have better heat dissipation facilities. Also, these units will generally require an external 12 volt DC power source (vehicle), which also allows them to run at higher power.
- No formal operating procedure. Key down and talk.
- FRS/GMRS will easily accommodate most group outing requirements.
- FRS/GMRS radios can be purchased with NOAA weather channel reception.
- Easy to acquire
- Little to no licensing
- Easy to operate
- No formal operating procedures
- Shortest range due to FM (versus other modes)
- Shortest range due to UHF (versus other frequencies)
- Shortest range due to power output
- Channelized frequency selection (HEY, WE'LL BE ON CHANNEL 7).
- Better range than FRS/GMRS due to operating in the HF (High Frequency) range.
- Better range capabilities than FRS/GMRS because it operates in AM mode, which requires lower power to transmit due to lower bandwidth use.
- CB in AM mode is limited to 4 watts of power output.
- CB does not require the use of an FCC license for non business use.
- CB radios are built in a handheld format, but these suffer from reduced performance due to the handhelds smaller sized antenna transmitting on the 11 meter HF band.
- CB will easily accommodate most group outing requirements.
- CB radios can be purchased with NOAA weather channel reception.
- CB is monitored by some law enforcement / emergency services agencies on a designated emergency use channel (9).
- CB has a general calling channel (11) (HEY DOES ANYONE WANT TO TALK? YEA? LETS SWITCH UP TO CHANNEL 20).
- CB has a road conditions/info channel (19).
- Easy to acquire
- No licensing
- Have squelch and attenuation controls for receiver tuning
- Easy to operate
- No formal operating procedures, other than respecting channel designations
- Good range for social use
- Waning use due the ease and popularity of FRS/GMRS
- Larger antenna requirements than FRS/GMRS. Think damaged antennas due to drive thru's, trees, etc..
- No privacy channel option. You're going to hear everyone on your channel within reception range, even if they can't hear you. This is where receiver controls come in.
- HF performance characteristics. You may not be able to reach your friends ten miles away due to atmospheric skip, but you may get the old man on the mountain in the next state.
- Illegal amplifier use may cause interference from long distances.
- Uses direct frequency input for receiver/transmitter tuning. No channelization.
- Individual units have memory banks (many units have alphanumeric) where you can save your "favorites".
- Has a privacy side tone ability, like the FRS/GMRS radios, in a non channelized format. (It's actually the same system, only not using the channel assignments and manually entering the tone frequency)
- Multiple modes of operation. The most commonly used mode for mobile is FM.
- Handheld units are offered by many manufactures and generally put out 5 watts at max power due to exposure limits. These units can be powered by rechargeable battery packs and/or disposable batteries.
- Around 50 watts is a normal capability for many mobile rigs. More advanced rigs may put out up to 100 watts.
- A nationwide repeater network is available for wide range communication. A repeater is a stationary automated amateur radio station that takes your radio broadcast and rebroadcasts it for wider ranging communication. The majority of repeaters are for free public use supported by a local amateur radio club. Very useful for the lower power hand held units.
- You must be licensed by the FCC to transmit on amateur radio frequencies.
- There are different tiers of licensing. The initial license is not hard to get and is obtainable through your local amateur radio club. These clubs are very willing to help newcomers.
- There are formal but uncomplicated operating procedures.
- The most popular mode/band for off roading amateur radio is FM mode on the 2 meter and 70 cm bands.
- Most handheld and mobile FM rigs will operate on both 2m & 70cm bands.
- Most capable form discussed here.
- Repeaters that can take your signal and boost it out over a wider range.
Cons
- Equipment only available online or in large metro areas.
- Requires a license to use.
