Xterra
Thenorthremembers
Modesto,Ca
2002 Nissan Xterra
Asking $6,700. Serious offers considered.
Located Turlock, CA
I've spent a lot of time building this rig, and I hate to see it go but I need a truck.
What I've done to it-
Suspension: Nisstech 2" lift with Bilstein 5100 shocks, extended shackles, Custom Alcan leaf spring pack (300lb over stock), 1" body lift to clear tires.
Rear bumper: custom work by StellerBuilt in Sac. Has dual fuel(or water) carrier, spare tire carrier, fold down table for food prep, hi-lift jack mount, recessed tow hitch so you don't drag it. Chopped 6" of rear fender and capped for a great departure angle.
Baja Rack with ARB awning (overbuilt Baja mounts) also added quick fist mounts for shovel.
CB radio/antanae. ARB rear diff breather kit, Dometic drawer fridge, Brand new Optima battery. 5 Brand new Cooper STT Pro tires(285/75r16)
Maintainance: All new fluids for both diffs, transmission, transfer case, engine, radiator. New spark plugs, timing belt, water pump, crank/cam seals, distributer wires/cap, thermostat, rear main seal.
Headliner sags. a/c leak repaired but needs to be aspirated/charged.
If you don't want the fridge/awning/tires I can remove and deduct from the cost
