Turns out, Moab is the perfect place to test a new setup. After dealing with a failing transmission, I proceeded to swap in an AX-15 from advance adaptors. At the same time we changed our sleep setup from a ground tent to a Crashpad double swag. All in all we are loving our new setup, although not having a failing transmission helps. Watch as we test out the new AX-15 conversion and the Crashpad Gear double swag.
What is the biggest upgrade/modification you have done on your own? Where is your favorite place to test out a new setup?
