Water gathering
Gtd3692
Troy, Pike County, Alabama, United States
Garrett
Davies
So I have a tank built into my truck with a 12v pump supplying the water from a port in the bed it works great, the only issue I have is when it runs dry on a trip. Any ideas on the best way to get water up to the fill neck? Preferably filtered to drinking level en route to the tank. The plan would be to be able to park near a creek or river and throw something in the water to then fill the tank on the go. Any ideas would be greatly appreciated.
Billiebob
earth
Bill
So you want a 2nd pump to run the stream water thru the filters on the way to the tank. Using the existing pressure system introduces "dirty" water to the distribution system.
And you could install a tee in the fill neck, or port it directly into the tank with a second "fill port" and have the filters/pump in that line. I'm thinking since the fill pump will be in suction mode it will need to be larger than the pressure pump. And suction pumps only lift a few feet so the in stream foot needs to be as close to the truck as possible. Best if you can park in the stream.
K12
Endurance III
5,786
Idaho, United States
Beau
K12
Air Force
I always carry an MSR water purifier. It is a hand pump and works fantastic. I do it into the MSR bladders but im sure you could work it into a water can or something to fill your tank. Can use it from any water source and make the water drinkable.
Reactions: Gtd3692
Downs
Hunt County Texas
Joshua
Downs
KK6RBI / WQYH678
USMC 03-16, FIRE/EMS
Get one of those gravity fed filter bags and just hang it over the tank. You can also rig something up using a RV pump and a Sawyer filter with some flexible PVC tubing and just break it out when you need it. Put a pre filter on the suction end that goes in the water to protect the pump and increase the life of the filter.
Gtd3692
Garrett
Davies
Great idea thank you!
FishinCrzy
South Carolina, USA
Rob
Duncan
StateHazmatResponder
A paint filter/cheesecloth/funnel into the gravity filter maybe with a bucket/pail? I have a gravity filter that holds about 2 gallons?? No ideer how long it takes to filter. Could take a while for 10 gallons or so. Low tech though.
Sez 2L/min. So, not that long!
Reactions: Downs
