Warn Winch?
Rob Frank
Akron, Ohio
Robert
Frank
looking to get a winch this summer, years ago I was looking at the Warn 9.5CTI, and now looking at the Warn Zeon 10-Platium and the Warn Zeon 10-S.
I guess the big difference is that clutch is electronic in the Platinum and a few extras. How importing is it to have the electronic clutch? I know a friend who has the 9.5CTI and to move the clutch one it took quite a bit of force with a pair of pliers. Is this an on going isle with moving the clutch? Or has Warn updated since the CTI line to make a clutch easier to move with the road abuse/salt?
https://www.quadratec.com/products/92136_0203_07.htm
https://www.quadratec.com/products/92136_0221_07.htm
Anchor Mtn
Venice, FL, USA
Gilbert
The remote clutch is great for hidden winch mounting systems. If you can get to the clutch lever, save yourself the money.
The Zeon clutch levers are larger than the little levers of the past but if you needed a pair of pliers to turn it, the winch was in a bind or needed to be serviced.
Reactions: Kent R
Rob Frank
Akron, Ohio
Robert
Frank
so having to use a pair of pliers is normal for moving the clutch?
Anchor Mtn
Venice, FL, USA
Gilbert
No, You shouldnt need a pair of pliers to move the clutch. IF you needed pliers, the internals were in a load-induced bind or needed serviced(greased).
A lot of people will store the winch in a bind... pull the hook/cable back in until the winch bogs and let off the trigger. Its not good on the system. You want it just tight enough to not let the hook rattle.
A winch does take on a lot of road grime/debris. It needs to be cleaned and serviced every so often, just like the rest of your vehicle. Its not a "bolt it on and forget about it until you need it" item
Reactions: Road
Rob Frank
Akron, Ohio
Robert
Frank
ok thanks
soonersfan
Oklahoma City, OK
Phillip
McIntosh
KG5LTZ
You should not have an issue with the Zeon. Big beefy clutch lever and smooth turning gears. The quality is quite apparent on these if you’re coming from anything else.
Reactions: TerryD
58-fc170
I would say keep the winch as simple as possible and avoid electronic clutches. A winch is relied on once everything else has some how gone wrong, a simple lever to turn will always work reliably.
Reactions: vegasjeepguy
vegasjeepguy
Gravette, AR, USA
I think of this every time I roll down my window with the handle in my Jeep and my wife has to replace another window motor in her Lexus.
