Type II Diabetes, Sleep Apnea (CPAP) and Cholesterol How do you maintain a healthy lifestyle on then Trail
PatriotT4R
Influencer III
3,984
Lillington, NC 27546
Hello, Everyone just wanted to throw this subject out there to see peoples responses on how they mitigate a possible medical emergency while on the trail. I'm 49 soon to 50 after my 20 year stint in the Military my health has declined a little partly my fault I admit but some ailments have come with age. My most troublesome predicament is type II diabetes which in the most part I have under control as long as I refrain from the sweets, testing my sugar levels daily are fairly simple in a controlled environment however, with the carbs sometimes needed for the trail to keep energy up this can be problematic. So when I go out out on the trail I bring diet drinks or sweeteners nothing with actual granular sugars. I also bring my test strips, along with my meter kit w/ alcohol pads, I can definitely feel the change in my body when my sugars are off up or to low. I also bring an A1C level check kit which can be found at Walgreens or most pharmacies, as long as my levels being under 7 I'm good but, there are times the levels do get higher give or take .3. Sleep Apnea is the other problem I was finally able to get my CPAP machine replaced with a newer smaller compact size which is perfect for the trail. However it is a pain to run a power supply directly to the machine which takes some figuring out usually I can run a power cord to a generator if available, but there are other times I do not have the option and I go without the use of the machine. Does anyone know if the market sells solar powered sleep apnea CPAP machines? So the last issue is controlling the two above mentioned problems along with high cholesterol ... Yep without the drugs and diet I would be a walking heart attack waiting to happen. Its difficult at best to maintain all these ailments so I would like to know who else on this forum has similar problems and how do you maintain a healthy lifestyle while on the trail?
Brian Glendenning
Socorro, NM
Brian
Glendenning
Hi - for sleep apnea my setup is a travel CPAP (ResMed AirMini) and a Yeti 400 Lithium Power Station, which I also use for other things while camping (light, coffee grinder, compressor for mattress, ...). This setup works great but isn't the cheapest.
Reactions: sjarvis and Kirk T
Pacific Northwest
Claggett
U. S. Army
You can get into a Pure Sine Wave inverter for 50-60 bucks. About a 400 watt unit, this well run the CPAC, it well also run most battery chargers that charge Li-Po batteries. I keep my insulin in the cooler. The CPAC pulls very little power, I don't think you well have a problem with a single 12v battery. I carry a Oxygen generator and need to be able to charge those batteries. Above 6-7k feet I need help breathing.
old_man
Loveland, Colorado
Tom
Houston
WØNUT Extra
I picked up some used cpap machines that work on 12v directly and they have worked fine. I paid $50 each. As far as the diabetes, check often, drink plenty of water, stay away from sweetened drinks.
Remember exertion and adrenaline effect your blood sugars and it varies from person to person. Check often. Keep sugar/sweets around in case your numbers go too low.
I take insulin, so I actually dial the dose back and monitor closely, adding a shot if needed. You are much better to run a touch high, rather than low. Remember to keep you insulin cool.
Reactions: Kirk T
KonzaLander
Traveler II
3,402
Junction City, Kansas, USA
KE0EBF
As a Type I diabetic who is under control, I fully appreciate your predicament. I have found that my insulin requirements drop dramatically when traveling because I am not eating near as much junk and I am staying more active than my 8-5 desk job. Knowing your medication and supply use is the most critical bit of information to know so you are not trying to track down prescriptions on the road. When I am on the road, especially when driving, I tend to check my glucose more often. While running high wont cause any immediate problems a low can be deadly.
In regards to maintaining control on the trail, I always wait at least 2 hours after eating or taking insulin before falling asleep to make sure I wont have a low in the night. I'm always packing fruit snacks in my pockets and extra bottles of orange juice in the cooler (soon to be fridge to better regulate my insulin temperature :smirk:). Your travel companions also need to know how to spot hypoglycemia and sometimes hyperglycemia and how to treat it. I usually keep some honey packets available for somebody to fill my cheeks with if I pass out and not have a glucagon pen available. I've never had problems on the trail, but by-golly I want to be prepared in case something does happen.
KCJAG
Shawnee, KS, USA
Geer
Type II diabetes can be cured with your diet. I am assuming that all above mentioned ailments could be cured by diet alone. Modern medicine has their hands deep in big pharma’s pockets. Modern medicine treats the symptoms with blockers and inhibitors. They don’t solve the problem by healing the body. Most likely one of your ailments led to the next and the next. Your doctor isn’t trained to cure disease. If it was me I would go full steam into curing these myself instead of living behind lines of pharmaceuticals. It can be done. I highly recommend www.dietdoctor.com which is the best place for the most information on a low carb diet and lifestyle.
I know that this diet works. I’ve lost 60 pounds on this diet and got rid of cholesterol medicine.
SilverSurferJKU
Calgary Alberta
Boksteyn
I can’t agree more!! The magic pill was a revelation to me. Once I started Keto I dropped 25lbs and feel fantastic with heaps of energy!
My friends dad was a bad diabetic, he started eating Keto over 10 years ago and is now totally off diabetes medication!
Reactions: Kirk T and Miss Roo
Jim SoG
Forums Manager
Educator I
10,890
Reno, Nevada, United States
Bro
USAF DAV
Mind you I know zip about this diet but one strke is I hate the taste of 89% of the veggies in the world, tried diff preps, diff sause, mixing with stuff, no good, my darn brain is stuck at 10 years old or something, now soot me or stb me I can deal with it, throw a veggie at me dude I am outta here......
So doe this diet doctor cover that? if so I will go buy it or watch it or whatever......
Thanks!
Reactions: Kirk T
SilverSurferJKU
Calgary Alberta
Boksteyn
Thanks!
My suggestion would be to try a greens supplement drink, it’s vegetables in powdered from one scoop into water or almond milk will supply you with the nutritional values.
But at the end of day eating real is the way to go.
Growing up I hated most things green my mom put on my plate, and looking back I know it was the better way to go versus the manufactured crap the the food industry is throwing out there calling it healthier then natural.
I’ll use a greens supplement only for a on the fly fix.
Reactions: Kirk T
KCJAG
Shawnee, KS, USA
Geer
Thanks!
Yes, go look at the site. Www.dietdoctor.com. It has a free section and a paid section.
Reactions: Kirk T and Jim SoG
dougruss3
Livingston County, New York, United States
Douglas
Russell
I have been following diet doctor myself. I have a paid subscription. It is well worth it. I don't have diabetes but do suffer from hypertension. I actually lost 10 pounds in less than a week on this. Love the idea of having all the protein and fats that you want and still be able to loose weight...lol.
Reactions: Kirk T
medic535
Georgia, USA
Brad
Y
w2wtf
go Keto diet on the trail, lots of water, 15g of carbs or less a day, the extra physical work you do should easily burn that, no beer/ booze and lose 25# to help the DM II and sleep apnea
Reactions: Kirk T
Rich_the4x4podcast
Lawrence KS
Rich
Young
Diet and exercise really are the best ways to help control diabetes and cholesterol. It may not get you off medications, but it will help. One of the most common causes of sleep apnea is being overweight. Again, diet and exercise. The science really is still out on the long-term effects of keto and protein-based diets on cholesterol. The best bet is avoiding red meats and sticking to lean meats. Avoiding carbs, as everyone knows, is going to help with your diabetes. Ultimately, what is going to work is a diet that you are able to stick to and maintain while at camp. A balanced, unprocessed diet, rich in very colorful fruits and vegetables, lean meats, fish, whole grains, nuts, seeds, olive oil, and lots of water is really the only diet that has been proven time and time again to be sustainable. What works for me, may not work for you. For health reasons, I switched to a vegetarian diet with the occasional splurge every few months of some fish or chicken (rarely at camp). All of the food travels well and very little needs to be refrigerated. Again, what works for me, may not work for you. I will say, it's has been the easiest diet change I've ever done.
Reactions: Kirk T
Kirk T
Palmdale, CA, USA
Kirk
Tylosky
KM6NIE
Army and Navy
Hello PatriotT4R,
That is a great question and thank you for bringing that subject up! First thanks for your service. I am also a veteran also and I am 52 and have the same issues. While I love going out and driving the trails and enjoying nature with my wife; I only do day trips as of now because I am very worried with my sleep apnea. Also, thanks for all the responses to tis delicate but very important question. It has helped me a lot with moving forward.
Thanks,
Kirk
Thank for the link. I also believe that diet can control everything, but it is so hard for me to control. I seems I lack self control.
Codebeagle
Elsinore, Utah, United States
Zachary
Porter
For a CPAP, I use a ResMed Airsense10 with a marine deep cycle battery and the DC adaptor. It's stupid heavy, but I get four full nights of sleep on the charge if I don't use the humidifier. I'm type II diabetic and control it through diet and some basic meds. I like low carb foods in general so I just plan meals with protein, veggies I do like, and a few fruits in there. So good meal planning there can go a long ways. I bring extra meds in case and have some snacks on hand to boost levels when hiking.
Interestingly enough, the more I overland and get outside, the better all the conditions get. You can do it! Have fun out there.
old_man
Loveland, Colorado
Tom
Houston
WØNUT Extra
Hello PatriotT4R,
Thanks,
Kirk
Everybody says that, and it may be true for some people, but in my case, I have lived on less than 25 grams of carbs for years. Even with exercise, the lowest I have been able to get my A1C without meds (pills and injections) is 7.5. The only way to get it lower is to completely fast. I did it for 45 days, a true no food, no liquids with calories and finally got my average to 132, even with meds.
