Truck Bed Removable Slide Assembly for Fridge/Cooler
Salty Taco
Satellite Beach, FL
Tyler
Jarvis
I have a Tacoma but know that this question/discussion can apply to all trucks or overlanding setups. I have searched the forums (kinda suck at it and still a newbie) and couldn’t find a good picture or details on a setup I’m trying to get.
Here is my idea...
Would like to be able to mount the cooler/fridge sliders to a piece of Plywood/heavy duty plastic or aluminum board that would sit in the bed of the truck for the sliders to operate while the fridge/cooler was in use but can remove the whole setup when not camping. To get back to a Daily Driver setup.
Concern is how to brace the board down to not flip up from rear while fridge/cooler is loaded and using sliders out.
I’m using a Iceco JP40 and there sliders but I feel the idea can be done for ARB, Dometic or any the other brands.
If this is as easy as responding to a link with another post please do and if ya have a setup like this feel free to post pics and or any advice.
RoarinRow
Elk Grove, CA, USA
Rolando
Nispiros
KN6JJS
Could you just strap the fridge down the the bed hooks somehow? Or build a system around / underneath the fridge that uses the bed hooks? That way you can just detach when you're done?
Reactions: Salty Taco
Salty Taco
Satellite Beach, FL
Tyler
Jarvis
Brilliant! Using the D Rings as a secure point in the rear of the board the sliders are mounted to would work to keep it from tipping.
Thank you for the quick reply.
I have a rubber Tacoma mat in my bed and I forgot they are there. I can cut a small hole there for the board to attach there.
I’m gonna mock something up and probably post it for reference.
Reactions: RoarinRow
Grendel
San diego
I just bought a TemboTusk fridge slide with the docking mounts. It is expensive but I wanted to be able to move the fridge from my tundra to wife’s 4Runner and use a slide. I also wanted to be able to remove the slide easily since I do use my pick up as a pick and do load a bunch of stuff in the back from time to time. The past weekend was the first I used it and I am quite happy with how it worked and the ease of removal.
Salty Taco
Satellite Beach, FL
Tyler
Jarvis
I did this in my Tacoma with a slide I built and installed. I put L track in the bed and then can bolt the slide in or easily take it out
Can you post a few picks of it? It not installed, installed and with or without the cooler/fridge? If not no worries. Just looking for inspiration. Thank you
RoarinRow
Elk Grove, CA, USA
Rolando
Nispiros
KN6JJS
Boom! Sorry I meant D rings. Good luck!
Bryan0302
Poquoson, VA, USA
Bryan
Leahy
USMC
Does anyone from this thread have photos? I am looking to do this with my 4Runner and an ICECO fridge I have coming.
