Tire Pressure Gauge - Which One is Accurate?
NotGumby
Mid Europe Member Rep
Frankfurt, Germany
Rick
Gumby
Army 11B
Hi Friends,
I’m looking for a recommendation for a accurate tire pressure gauge. I have three (TuffTek, ViAir, and “no-name”. Between the three there is a 7 psi difference. It’s driving me “crazy”.
Any recommendations? TÜV approved brands?
Thanks, Rick
Reactions: MazeVX
El-Dracho
Mid Europe Member Rep Germany
Supporter
Lampertheim, Germany
Bjoern
Eldracher
DO3BE
Hi Rick,
Uh, 7 psi or 0.5 bar is significant difference.
I use a tire inflator/measuring device of a type which are also used in professional workshops. It is alread several years old, made in France, cannot read the brand anymore as it is heavily used. It is sufficiently accurate for my purposes. If you want it to be very precise, I would use a calibrated device from a brand manufacturer in the workshop sector, e.g. Hazet. Or you can look here in Germany at the motorsports specialist Sandtler for a proper tire presure gauge.
Cheers, Björn
Reactions: NotGumby
BCNP4runner
Los Alamos, New Mexico, USA
Jeff
K
KI5FGO / WRFH471
Pick one and use only it. The absolute pressure isn't as important as being consistent.
I use Longacre stuff for setting the tire pressure on my race cars. They have always been accurate, but they are also fairly expensive.
I second Longacre. it is both consistent and accurate.
MazeVX
Gießen Germany
Mathias
Kreicker
So in Germany there's always a way out if you are searching for accurate measurements, buy something that is "geeicht"
By the way, those unprecise stuff drives me crazy as well, also the gauges doing triple of the necessary pressure making it impossible to read out the 1/10
I post you a link:
This is a calibrated version so the pressure is certified correct.
NotGumby
Frankfurt, Germany
Rick
Gumby
Army 11B
Hi Rick,
Cheers, Björn
Thanks for the two tips Björn I will check them out.
Rick
Reactions: El-Dracho
RoarinRow
Elk Grove, CA, USA
Rolando
Nispiros
KN6JJS
NotGumby
Frankfurt, Germany
Rick
Gumby
Army 11B
I post you a link:
Thanks for the link Mathias. I’m checking it out now. My ViAir is the same with no 1/10 markings.
Reactions: MazeVX
NotGumby
Frankfurt, Germany
Rick
Gumby
Army 11B
That’s a good point. The problem is the # of gauges. I’m willing to pay for accuracy, reliability, and durability.
Reactions: RoarinRow
slomatt
Bay Area, CA
I ran into a similar problem a while ago where all of my gauges read different values, which led to a bit of a rabbit hole learning about ASME gauge grading.
The tl;dr version is that there are two main grades:
- Grade 1A is +/- 1% across the scale
- Grade B is ±3-2-3% depending on if you are reading a side or middle of the scale
More info here
Grade 1A gauges are quite expensive, so I went with a Grade B gauge where my normal street pressure (~30psi) is right in the middle of the scale at the most accurate point. I've been happy with this, and it reads very close to a commercial digital pressure gauge I have for another project.
The above gauge is on my DIY tire inflater setup. I also have a "quick read" style gauge in both cars for fast pressure checks. These again are rated Grade B with my normal pressure in the middle of the range.
NotGumby
Frankfurt, Germany
Rick
Gumby
Army 11B
More info here
Thanks for the link and suggestions!
Robert OB 33/48
Mid Europe Region Director
Supporter
Pathfinder II
4,387
Gaanderen
Robert
Keim
Well, actually I know for sure that there is always a difference between them.
So, what I do is I have a compressor with gauge at home.
Will check with that one and then with the one I have in the car.
I notice the difference and when I am airing up at a gaststation or such, I can check with that one.
Always the one method that suits me.
MegaBug
Colwood, BC, Canada
Matt
Lester
My T4R has TPMS readouts and I assume Toyota wants me to set the recommended pressures to read correctly on their system. My tire pressure gauge is 2 pounds out, so I adjust accordingly.
El-Dracho
Supporter
Bjoern
Eldracher
DO3BE
Hi Friends,
Thanks, Rick
So, which one did you end up buying?
Reactions: BCNP4runner
NotGumby
Frankfurt, Germany
Rick
Gumby
Army 11B
Hi Friends,
Thanks, Rick
I didn’t want to spend the money on yet another gauge, so I’m following the advice pick ONE and use it. Staying with the TuffTek. The rest were banned to the garage.
Get Out GO
Regional Director, Africa & Middle East
Randburg, South Africa
Christoff
Eilerd
If you do get to a stage where you want to change, I can highly recommend IndeFlate as an In/Deflator and guage;
Reactions: MazeVX and NotGumby
