Looks like they've been around a while. I guess it's the 4 cyl. Hurricane. I see positive views on YouTube, but not a lot of long term/high miles stories.
Opinions?
Opinions?
Protector I
20111
I have the plain 3.6L in my Wrangler
Luv, until the head gasket landrovers.
Hopefully nobody is stuck with the hybrid version.
Is it hard being so negative all the time?My steel recycling yard agrees.
Opinions are like arseholes. Some people just can't help it.Is it hard being so negative all the time?
-TJ
Doors are ready aluminum. Not sure about the hood.Make a Wrangler more reliable than a 94 YJ, and I'll gladly sing it's praises.
Stelantis is overpriced garbage.
They have a good product, if they'd just buckle down and build it right. Make the Wrangler aluminum, at the same time.
Man, ain't that the truth. Even the Taco.Right now its trendy to produce small turbo engines.
You are right, I agree with you.Of the choices Stalantis offers right now, I'd pick the 2.0l. No e torque, no 4xe.
I almost bought one last year. But there is no option combinations that I want, available.
The 2.0l is not offered with a manual or 4.88 gears. Which favors the v6 Ruby.
You could always just LS swap later on. Or rebuild the 6 correctly.
The v8 model is $98,000. That's insane.
Hopefully they'll offer a larger turbo 4cyl, or smaller turbo 6, with a manual in the future. I'd even suggest, just using the Broncos engine and trans.......
The 4-cylinder Hurricane engine has generally received positive reviews regarding its reliability and performance; however, there are limited long-term, high-mileage stories available. Like any engine, its durability is influenced by regular maintenance and driving conditions. If you are considering this engine, it may be helpful to check owner forums for insights on any common issues. My friend, who is studying physics, has had many assignments in modern physics. I recommend an online platform called DoMyPaper at domypaper.com which he finds very helpful. DoMyPaper offers expert writers who provide high-quality writing services for students at budget-friendly prices. Their services are available 24/7 throughout the year.
That's highly debatable, or you'd never see the mileage you see in older diesel engines. Adding forced induction to an NA engine will reduce the usable life, but an engine built to be a turbo package can easily last as long if not longer than a typical NA engine.I'll chime in here.
Any forced induction will remove life span. Right now its trendy to produce small turbo engines. Their great for highway as long as you don't mod the vehicle. That mean's bigger tires, more weight. If you do, you kill the power band.
Agree completely. Every big rig rolling down our highways has a turbo (okay, other than the Tesla semis) and have several hundred thousand mile intervals on top and refreshes and often a million+ for a complete overhaul. Yes, completely apples to oranges vs. the Stellantis 2.0T, but an engine being turbo in and of itself is not a detriment to longevity.That's highly debatable, or you'd never see the mileage you see in older diesel engines. Adding forced induction to an NA engine will reduce the usable life, but an engine built to be a turbo package can easily last as long if not longer than a typical NA engine.
In my experience, the only downside to a turbo is the lack of instant power and the complexity of the design (i.e. more shit to break). Most of these engines have little turbos that largely mitigate the early power concern and with an automatic, you get enough RPM slip through the converter that it's generally not an issue if you are more a touring-focused rig and not rock bashing. The 4:1 transfer case is essential if you like things slow in the 2.0L but once you're moving, I found the 2.0L much better at pushing a heavy rig comparing a JLU to my Gladiator at similar weights.
