Hello, Overlanders. I am looking for information on routes and remote camps near Tahoe, CA, as well as any info on running the Rubicon. I’ve heard there are bypass routes around some of the toughest parts and just want to confirm. Thanks.
Bypass, or not, the Rubicon is a serious trail with serious obstacles. We did it in a Jeep JKU HR with the Jeepers Jamboree group and have the dented skid plates, door nick and rubbed fenders to prove it. The first section out of Georgetown is relatively easy, but it gets serious quickly. Coming in from the Tahoe side is OK for a ways in - it all depends on your experience and vehicle capability.I have never done the Rubicon, but have don lots of quick off roading trails in North Lake Tahoe. I have heard that there are camp sites as you near the completion/end of the Rubicon Trail - Rubicon Springs area. I would download the All Trails app, also this time of year can be tough as many of the off road trails have steep sections that are tough when wet/frozen.
Good areas to find off road driving trails:
Prosser Creek Reservoir
Boca Reservoir
Stampede Reservoir
From what I've heard about the Rubicon, the extreme sections have bypass routes... but many of the tough/difficult sections do not. Again, I've never been out there myself.
[emoji50]The Rubicon is a serious trail and chances are your mostly stock Tahoe won't make it through the gatekeeper or if it does, off the trail. You'll want front and rear lockers, no trailer, openness for body damage in a full size rig, lots of spare parts and fluids and the know-how on replacing them, a good spotter and second vehicle, and a winch to help you up some of the winch hills.
Jeepers who run the Jamboree will say differently, but that's a highly experienced guided run in a much smaller and more stock capable vehicle. Not to mention boulders that Jeeps can go around, full size rigs have to go over.
I've run the trail a couple of times and our groups have experienced every breakdown including, blown hubs, driveshafts, axle shafts, wheel bearings, cracked oil filter, ring and pinion failure, steering box hoses blown, cracked water pumps, bent and broken radius arms, roll over, blown up ball joint, cracked axle knuckle, and so on. Lots can go wrong when fat rigs are trying to go over Civic-sized boulders while off-camber.
For sure! Dont even try without a winch and at least one more vehicle with you
I've been gone from California for years and I didn't know they did that. What a shame!Now that the Gatekeeper and Little Sluice have been blown up it's pretty much a paved road (not really). :) Pictures are from before the dynamite.
http://www.rubicon4wheeler.com/2012/09/the-rubicon-trails-little-sluice-box.htmlWho blew up all the obstacles?? I had never heard of that either. Of course I only really know the trail from youtube videos, mostly Trail Recon's vid series.
Well, after looking through that stuff it looks like they really took the teeth out of the trail. Honestly looking at that I dont even think its worth it to me to build a rig to run it...
Don't worry, the Rubicon still has plenty of nasty surprises to dent all parts of your rig!Well, after looking through that stuff it looks like they really took the teeth out of the trail. Honestly looking at that I dont even think its worth it to me to build a rig to run it...
Pathfinder II
I have run it both directions so to be clear, unless you are really set up for rock crawling, going in from the Tahoe side (commonly known as running it backwards) you should not venture past Observation Point. Cadillac Hill is just past it and depending on the rock placements is a real deal obstacle with no bypass.Bypass, or not, the Rubicon is a serious trail with serious obstacles. We did it in a Jeep JKU HR with the Jeepers Jamboree group and have the dented skid plates, door nick and rubbed fenders to prove it. The first section out of Georgetown is relatively easy, but it gets serious quickly. Coming in from the Tahoe side is OK for a ways in - it all depends on your experience and vehicle capability.
Dan
