Seat Swap
BlueLineOverland
Local Expert, Arkansas USA
Experimenter II
6,585
Ozark Arkansas
Mason
Berry
Has anyone ever done a seat swap for more comfort? I was trying to see if it was possible to swap an XJ seat for a more long haul friendly seat. I'm not sure its even possible, but worth a shot asking.
Big Red Ripper
Nebraska, USA
Heath
Rippentrop
Have not done it myself yet, but know others who have. The ZJ and some WJ had the same (or very close) mounting holes on the seats themselves. You would need to reuse the tracks from the XJ on the ZJ seat.
https://www.cherokeeforum.com/f51/zj-seat-swap-233289/
Here is a pretty decent write up of the swap. Hope this helps.
BlueLineOverland
Experimenter II
6,585
Ozark Arkansas
Mason
Berry
Welding Goats
Midland, TX, USA
Ronn
Reeger
WRXB227
Are you wanting to swap out to aftermarket seats or to a different make/model/year seat out of something else?
JungleSkunk
If you have a welder and minor fabricating skills almost any seat can be swapped in with some limitations. The hard part is getting the sliders and such to work correctly on oem style seats without adding aftermarket or custom sliders.
I like the Corbeau "racing" style seats with harness's but it does require a little work to get them in some vehicles. Corbeau makes a custom seat bracket sliders specific to your model which makes it a little easier.
https://corbeau.com/master-seat-brackets
PCO6
Newmarket, Ontario
Stew
Beatty
I swapped a pair of Hyundai Tiburon seats into my XJ. I had already made the same swap in my TJ & LJ so I was pretty sure they would work. The original seats in my TJ were in rough shape. Reupholstering them would have been costly. Seat covers would have been less expensive but I didn't find anything I liked and that fit well (although some do). I wandered around a junk yard until I found something I liked and bought a pair of Tiburon seats for $100. I've since got them for as little as $70 CDN for a pair. The ones I've bought have been from cars from about 2000 to 2005 but I'm sure others would work.
They are a combination of leather and vinyl and they are VERY comfortable. I've put a lot of miles on these in 3 different Jeeps. They also come in fabric if that's what you prefer. I've only found non-power seats and that's fine with me. Seat heaters were an option but I have not found any. I have since put a set of Dorman seat heaters (Pt. # 628-040) and it was an easy job.
Here they are in my XJ.
This is from my LJ but it's basically the same as what I did in my XJ. In the XJ I used the original sliders. For some reason the Tiburon sliders fit better in the TJ & LJ. I made simple 1/4" flat bar brackets and used grade hardware (not what's shown in this pic). I could have welded them together but there really was no need to.
Here's what they look like from the rear in my TJ.
If your XJ is a 4 door you will have a lot more options. Mine is a 2 dr. so I wanted seats that folded forward. Seats from a small 2 seater worked well.
