Rear jk springs | OVERLAND BOUND COMMUNITY
Rear jk springs
Discussion in 'Overland Vehicle Gear' started by Fellow Jeeper, Jan 8, 2019.
Hi Guest, Become a Member to gain access to the Member Forums, Member Map, Member Calendar of Events, and Rally Point overland trip planner! Click this link "Learn More" for more information!
  1. Fellow Jeeper
    Fellow Jeeper Rank III
    Latrobe Pa
    Map
    Morning everyone. Have a quick question. I have a 3.5 Rubicon Express lift. My rear coils are starting to sag. Due probably to all the extra weight i put on almost every weekend in the summer. Has anyone upgraded the 3.5 to the aev springs or metal cloaks? I liked the aev 4.5" heavy duty spring but then my jeep wont fit in the garage. Im not sure but i think both manufacturers are progressive rates. Any issues after install? Thanks
  2. Anchor Mtn
    Anchor Mtn Rank III
    Fruita, Colorado
    Member #:
    3935
    Map
    You can switch to the Teraflex 3.5" Outback rear springs for the same height but more weight carrying capacity.
    Bucksoverland and Graeman like this.
  3. Fellow Jeeper
    Latrobe Pa
    Map
    Thanks for the tip. Do you know anyone running them?
  4. Captain Chaos
    Captain Chaos Rank V
    Member Supporter +
    Liberty Lake, WA, USA
    Member #:
    3821
    Ham Callsign:
    KI7TFB
    Map
    When my teraflex coils started to sag, Teraflex told me to look into their coil spacers. I stuck 3/4” spacers in the rear and I haven’t had a problem since.
  5. sabjku
    sabjku Rank IV
    Alexandria, VA
    Member #:
    13840
    Map
    I ran into the same issues a few months ago with the Rough Country 3.5 springs I was running. I switched out to the ARB Old Man Emu Heavy Duty spring and shock combo, and then went for the optional 600lb rear springs from OME. Completely different stance now, and feel. Definitely rides much better with the heavier duty springs.
    Graeman likes this.
  6. Anchor Mtn
    Anchor Mtn Rank III
    Fruita, Colorado
    Member #:
    3935
    Map
    Yes. We put a set in for a customer that was towing a heavy pop up trailer and they helped a lot .I also have a friend running the entire outback suspension and he loves it .
    Fellow Jeeper likes this.
  7. brien
    brien Southwest Regional Director
    Staff Member Moderator Member Supporter +
    Tucson, AZ
    Member #:
    3553
    Ham Callsign:
    K7XPO
    Map
    I also have the OME heavy load springs in the rear and it completely eliminated my sag issues. The ones I run specifically are the OME 2620 for a 2.5" lift, I believe they make one for a larger lift, you'll probably have to call OME/ARB and talk to somebody to get the right parts. Alternatively, for a less permanent option, look into an AirLift 1000 kit. We ran that as a temporary fix while we waited for our lift parts to come in.
    sabjku, NovaBound and Fellow Jeeper like this.
  8. Fellow Jeeper
    Latrobe Pa
    Map
    Thanks. I like arb stuff. I'll give teraflex and arb a look. Thanks everyone
    sabjku likes this.
  9. jeeping62
    jeeping62 Rank I
    Ogden, Utah
    Map
    I’ve had the same problem with my springs on my JK, I have tried Rubicon express – TeraFlex – BDS in 4.5 inch and they have all sagged I have an off road trailer that ITow about a month ago I went to AVE heavy duty over landing springs made all the difference in the world and then for sharks I’m running the TeraFlex falcons A completely different ride and definitely handles the weight
  10. jeeping62
    jeeping62 Rank I
    Ogden, Utah
    Map
Share This Page
